Thread Cutting Jig
Woodie49
>Does anyone know of any Plans for a Thread Cutting Jig?
Thanks
Thread Cutting Jig
Woodie49
Thanks
Re: Thread Cutting Jig
don lewonczyk
>The plan is save your money and buy one,ask John Lucus about his Baxter jig. I think there was something along the lines by Al Crandell that your looking for, looked pretty good and should be in the archives. DonL
Re: Thread Cutting Jig *LINK*
>Hopefully this will get you to the plans and photos for Al's threader.
I also have plans for Jean Micheal's threader but I only have hard copies for it so if you want them you'll have send me an e-mail with your snail mail address. I won't have access to a copier until after the 5th however.
http://www.cicaaw.org/node/view/787
Dick Mahany - Morgan Hill, CA
>Although I don't have any plans, I made this simple threading jig by welding two nuts to some square tubing and mounting it in a Bitmore vise. Gives all the neccessary degrees of freedom, and I can easily use the vise on the drill press when needed. The arrangement was blocked up to the center height of my 16" Jet lathe. I used a 14 TPI rod which screws directly into a Oneway chuck adapter and plan to make a coarser 8 TPI (larger diam bolt below) version next. The threaded rod and nuts came from McMaster-Carr. I'm sure a welding or muffler shop could tack the parts together inexpensively if needed.
>Sorry, PIC didn't go first time.
Good job
Woodworm
>Wivamac do a Thread cutting jig.
http://www.toolpost.co.uk/pages/WivaMac_Lathes/Technical_Specifications/Ornamental_Turning/ornamental_turning.html
also
Re: Good job
paul waddle
>John, tell 'em to build in a swing arrangement to ck threads without moving other settings-well worth the trouble. I just took out one bolt on my jig and it works. pw
Fred Holder
>Before I wrote my book, "Making Screw Threads in Wood", I made up a simple threading jig to cut threads. Since my lathe at that time had a 3/4" x 16 tpi spindle, I used a 3/4" bolt threaded with 16 tpi and a couple of 16 tpi nuts. The jig was mostly made of wood and worked pretty well. It simply mounted to the tool rest banjo and precision adjustments were not available, but it could be fiddled into position. It was no more difficult to adjust than the simple threading jig sold by Craft Supplies Ltd. in the UK which also fits into the tool rest banjo. I've included a picture of it here. There is a picture and description in my book.
More Woodturning Website
paul waddle
>Howdy Fred,I bought your book and enjoyed it. Now to pat my own pertard,I believe,if you will refer to the homade threader that I made, and using the principle of the ornimental lathe,I made a captured nut and stud screwed into the threader shaft to advance the wood into the cutter. Seems like this would be better for a homade version,not being machined as close tolerance as the Nova,for the nut instead of a thread (v tool) follower to engage the thread. Same idea. By the way,which is the preferred sequence;to make the top, internal thread portion or the bottom external thread first? The Nova does have the advantage of rotating the work pc out for checking thread fit.. Come to think of it,your homade threader could have different pitches: 3/4- 10,1/2-13 5/8-11 6mmx1 or any nut and bolt in the hardware store. pw
Thanks Fred Most interesting.
Fred Holder
>Hello Paul,
If you are using hand chasers, it is best to make the inside threads in the lid first, because you have the ability to simply make your box shorter when making the external threads. With a threading jig, you have a better chance of getting good threads and all you need is some guide on what size to make the recess and the tenon. Since you have my book, you already have my recommended drawing sizing the recess and the tenon, but for the many people who don't have the book I'm including the drawing in this post.
With the threading jig, I've used this drawing to size both the tenon and the recess and then cut the threads and have the two pieces screw together perfectly the first trial.
Personally, I prefer hand thread chasing, because I can generally chase the threads while I would be setting up the threading jig. However, if you have many pieces to thread at one time, the threading jig is much faster.
