>I finally broke down and bought a Henry Taylor thin parting tool for box making purposes. For the life of me I can't figure out how to sharpen the dang thing. All I have managed to do so far is to make a nice hollow form on the end of the long point. Can anybody help me out. Thanks, Bob.
>I just turn the grinder on then turn it off and sharpen on the 120 wheel while the grinder is coasting. Doesn't take but a touch. I do the same thing with my little tiny spindle gouges.
>Set the tool rest to be perpendicular to the wheel (90�) and lay the parting tool flat on the tool rest. Sharpen one face, flip the tool over and sharpen the other face. Flipping the tool compensates for an errors in the tool rest angle.
This puts a slight hollow grind on the two faces and the parting tool will have small sharp spurs on the outside of the cutting edge. And that gives a cleaner cut.
>I use my diamond parting tool as sort of a mini skew. I will often part down to a depth and then clean out that depth using the parting tool like a skew. This is handy for fillet's and for the area next to beads on my mirrors.
If I were to hollow grind the bevels wouldn't it leave the tip with a cove shape instead of flat like I get now. The hollow grind makes sense if you only use the tool as a parting tool but I'm not sure it would work for the multiple ways I use a parting tool. I may give it a try in the next few days.
>I use a parting tool for a lot more than it's name would suggest, and grinding it across the bevel makes the diamond parting tool all the more useful. That little dip across the front isn't enough to make any difference when using it as a skew or a bedan; and the little burr made along the edge from the grinder or stone makes it a useful spear point scraper when laid on its side. I use it this way for turning beads.
The nice thing about this cross-grind is that the points on the tip and the edges can be kept sharp with diamond card or slipstone, and there are many sharpenings until the hollow is removed.
Anyway, it is another way to get more use out of a parting tool, and like most other things we can do to truning tools, you can use it if you like it, and forget about it if you don't.
>I use diamond parting tools, one is 1/8" and the other is 3/16". I use them not only for parting but also for cutting recesses in the top and bottoms of boxes. I start the cut by lowering the tool into the wood and then skew it to the left to cut from the center. If the tool is sharp you get a very smooth surface.
On some of my boxes I can use the large curved edge of the 3/16" tool to help shape the curve of the bottom while it is still being held by the chuck. It will reach into places that my gouge cannot and where my skew skills need improvement.
Also increasingly I am using my 3/8" beading/parting tool like a skew. I love the way it shears end grain.
