ADVERTISE HERE - FREE TRIAL
Hollowing Tip Jig
Hollowing Tip Jig
Hollowing Tip Jig
Eric Knutsen
>I had the opportunity to take a class with David Ellsworth 2 yrs ago. During the session he showed us how to make our own hollowing tools. He then showed up how to take the cutter tips and dowel the ends to insert into the hole you will drill in the end of the drill rod. He had a great little jig that held the tip firmly and slid up to the grinder wheel and turned a handle much like a pencil sharpener set up which turned the tip against the wheel and produced a perfectly round shaft which could be inserted into the hole and CA glued. I contacted him about plans for/or to purchase the jig he had. Unfortunately neither are available. I've tried holding it in vicegrips and knocking down the corners but so far no good. If anyone has constructed a jig to do this and you're willing to part with your idea, I'd be very receptive... Thanks.
Re: Hollowing Tip Jig
Greg Haugen
>Eric,
Actually this year in the secret santa exchange I got something I used for this very application. It's a handle "jacob's" chuck. I can place the tip section in the chuck and simply rotate the handle, which is easier to rotate than a vise grips, to grind the square section round. This handled chuck is also nice for drilling stuff on the lathe by hand.
There should also be a way to do this on the lathe. Maybe by using the spigot jaws of a chuck to hold the tip section and then either taking a old small grinding wheel held by hand to grind the corners off or use a small stone in a dremel.
I've been using the handled chuck and it works great.
Greg H.
>I don't bother. I use 3/16" square bits and drill a 1/4" hole for it to fit in. Sometimes you just barely have to knock a few corners off to fit.
You can chuck it up in a hand drill and then grind it on the grinder. It might leave the tenon off center but that doesn't matter.
Re: I'm with John- stick them into .....
Jamie D
>.. a drill chuck and grind away the square corners so that it fits into the hole size you drilled in the tool shaft. Thick CA glue makes up for somewhat sloppy tolerances!
John Jordan uses...
bob elliott
>...a similar "pencil sharpener" device. Maybe he will post a picture???
Re: John Jordan uses...
John Jordan
>It would be a fair amount of work. I can take a picture, though. I never used a "machine" until I started making them to sell. True/clean your wheel well. Grind off each corner gently, and you have an octagon, and it's then a small step to round. If you start off just trying to "round" it it won't work as well.
You could also just drill a 1/4 inch hole as someone suggested, and then put a 10-32 setscrew in it. Then you can take it out to sharpen it.
John
Eric Knutsen
>Greg, I know you said you got it as a gift, but where could I get a handled jacobs chuck. That sounds like a great idea. By the way, there are Haugen's in my family tree. Where are you from?
John Jordan
>The trouble with a Jacobs chuck is it has THREE jaws, which wont really grip a square. You can find cheap air die grinders that have a four slot 1/4 inch collet-they are not all that type, you have to check. .The corners of the 3/16 cutter fit in the slots That's what my little machine is made with-I just took the shaft out. You could rig the die grinder to advance against the grinding wheel. That's just too much air for making a lot of them.
John
