Wax Finish for Bowls Used for Food
Richard R. Steussy
>Some time ago I posted a message looking for a good finish for the bowls I turn which are used for food. At that time, Jim Pugh of Ohio sent me a wonderful recipe for a wax which I've used ever since--it's great stuff and I'd like to share it with you.
I wanted a patina look with a dull, yet rich look and this does it. You don't need any preparation other than sanding to 320. You then just smear it on and buff it off! And you can easily repeat the process later on when the wax starts to wear thin.
The formula: 1 part beeswax to 4 parts mineral oil and microwave it to a liquid. Then after it cools it's like shoe polish. Just smear it on, then buff it lightly. I like it because some of my segmented bowls had light woods in them which looked "tacky" when I used Walnut oil on them. This wax brings out all the richness of the wood without darkening it in any way. And it's safe for food. Thanks, Jim.
Re: Wax Finish for Bowls Used for Food
>Richard What kind of times did you use on the microwave. I'd hate to burn my house down. A friend gave me some beeswax pellets and I've been wanting to make a blend like this to see how it works.
Greg Haugen
>This is one of the oldest options for a finish on a salad bowl. It's definately been "tried and true". Due to the temperature variations and different "power" levels in microwaves I've always made it on the stove top. Let's face it-Mineral Oil is a "petroleum" product, the majority of the MSDS sheets on will list one of the oil companies, Pennzoil is often listed, as the maker. Extreme potentials for heat would not be advised-it will burn. I often made small containers of it to go with the bowls that are purchased-so I'd make a single large batch. Or I've made myself a large "batch" for the shop. For this, I'll use a double boiler setup to heat the ingredients. Or if I'm running low and just need one to go with a single purchase, I'll make a "double boiler" with a small sauce pan, some water, and a baby food jar with the ingredients in it. By using the stove top, I'm able to easily control the heat, start low and gradually raise it until the oil heats up enough to melt the wax. No reason to over heat it.
Indeed, double-boiler is safest
Bill Howatt
Re: Beeswax melts at 145 degrees F
Russ Fairfield
>There is no need to get carried away with the heat.
Richard R. Steussy
>John--I microwaved the 1/4 cup solid beeswax and cup of mineral oil until it blended. It only took about 90 seconds. (with pellets it would probably be less.) I just watched it until it was all liquid. I never thought about any fire danger! (but I do have an extinguisher close by). Dick
Wayne Fladby
>A better way (and safer) is to buy some Claphams Salad Bowl Finish.
