REAL MILK PAINT
Jet 1220VS lathe. What's the ...
Ed Moore in SW Virginia
>scoop on this new lathe. It has a 3/4 HP motor, but is that enough?
I have a Oneway 1018, but would like to get a second more portable small lathe. I would appreciate hearing the opinions of those who have a Jet 1220VS or have tried a 1220VS. I find a Jet 1014 and 1014VS to be underpowered.
TIA,
Ed
Re: Jet 1220VS lathe. What's the ...
Greg Haugen
>Ed,
I guess it depends on what your planning on doing with it. It seems to me there is some "power" loss on the VS options compared to the "belt changers". I had a 1220 before upgrading to a 1642EVS, I found it did everything I wanted it to do; spindles, boxes, and bowls. I've often said the 1220 could be a mini "mustard" monster if WMH would have painted it yellow. Comparing the 1014 to the 1220 would like comparing the 1642 jet to the 3520B Powermatic. Both options are good, but it's obvious to have the extra power (1/2 horse to 3/4), weight, and swing.
Another possible option, if John Lucas would chime in, would be the new Delta. I think he's turned on it. It has a EVS option with a full horse option. If Delta would make a good solid mobile stand with it, they could finally have a "winner".
I do have one complaint about the majority of the "smaller" lathes available. In my opinion, once you get to 3/4 to 1 horse and a 12" swing I'd really like to see a 1" tool post for the tool rest and banjo. I have snapped a 5/8" post, while using a skew and didn't get a catch and wasn't aggressive. One way to solve the 5/8" cast iron rests would be to call Brent, or Bill G, and replace them with steel Comfort Rests.
Just my opinions,
Greg H.
>Greg is right. What I generally turn on a mini 3/4 horse would be fine. If you turn bowls and your aggressive you will want more horsepower. The 1014 only has 1/2 and with the VS model when you turn bowls you have to take very small bites.
I haven't turned on the new Delta. It's supposed to be out this spring according to the Delta people. I did get to watch my Friend Don Russel turn on it and he was really impressed with the machine. Don knows what he's talking about. It has a 1 horse VFD motor. Even though I understand you don't get the full horse when going to a VFD you still get much better power at low speeds when compared to the DC drives. I'm really looking forward to getting my hands on one. They made a lot of little modifications that makes the lathe a pleasure to use. The belt changing mechanism is really cool.
If you need a new lathe right now I would go with the JEt. If you can wait a little while I would at least give the Delta a look.
Bill Noce Northeast Ohio
>ED,
I got the 1220vs, I like it....I have turned on it for about 5 hrs. without the motor getting hot. I've turned some winged pieces about 10" long x 3to 4" wide with no problems other than normal between center slipping until you get to the smooth running point. As for portability it is alot heavier than than the 1018 it wieghts about 100 lbs. but its manageable. The only thing I have with is the light neck is to short but that is going to be solved by lenghtening the it flexable neck and rewiring it.
Jim Sample------WebKitFormBoundary4+bM8dU5Q5ZoYOET
>I had a chance to turn on the new Delta about 30 days ago at the Delta Tool open house in Sioux Falls. The controls for the VS and switch are on top of the headstock and out of the way for me (unhandy). I turn on a 1014VS and a 3520B so I may be spoiled.
The castings are a little rough, maybe it was just me. I plan to stay were I am.
Jim Sample
Re: Jet 1220 lathe light
GalenV
>Bill
I feel the same way about the 1220 light, the flex shaft is too short for bowls and hollow forms. Great at casting shadows!
I would be interested in how you extend. Flex conduit seems to limp and the garage sale lamp I got I could not match end couplings to add on. I have not been in a wholesale lighting store, just Lowes, to see if they have longer sections. Most lamps I see are about the same length.
If you get around to it you might email me what you do.
Thanks
Galen
Gordon Seto
>Bill and 5 of us got the 1220 VS together.
I am very disappointed at the design of the light. The reflector is too small and too short. More than half of the light bulb is exposed without a guard. That is not practical nor safe.
Besides having a larger horse power motor, the 1220 VS has 6 pulley positions. The 1014 VS has only 3 pulley positions. This change together with the minimum speed of 200 rpm solves the anemic power weakness of the 1014 variable speed vs. the 6 speed belt change 1014 model.
There is very little slack in the belt for changing pulley position.
Other than that, this is a joy to use. It is quiet, smooth running. The motor barely get warm.
Thanks to all who answered ...
>It sounds as if the power of the 1220 or 1220VS is sufficient, the lathes run smoothly, and the only complaint is with the light.
I regard the light as a non-issue since I can solve that problem with a little rewiring.
Now to look for the best deal -- which is half the fun.
Ed
Rob Wallace
Rob Wallace
>Bill, et al.:
A few weeks ago, I turned on the Jet 1220 at our turners group meeting, and I like it a lot - I have had a Jet 1014 non-variable speed mini as well as a Delta LA200 Midi for quite some time, and the features of the 1220 (in addition to the extra power) are well thought-out; clearly WMH has been doing their homework and had added some significant improvements on the Mini's design. I actually have since thought about selling my Jet mini (and/or the Delta midi) and buying a 1220, but the 1014 is more portable - it's lighter to carry, etc. for doing demos at various locations - the 1220 is considerably heavier (they've added carrying handles!). This would be good for someone who intends to fix the lathe to a heavy stand where portability isn't an issue. My Jet mini is the lathe I use for doing off-site demos at art galleries, for various groups, etc. and the 1220 (at least for me) is a bit too heavy for this role. I'll stick with the Jet Mini- (1014) for a while for my demos!
As others have already noted, my main complaint about this lathe is the lame light that is provided. It seems to me that they have limited the size of the on-lathe light due to space constraints in packaging of the lathe. It's far too short to be useful when doing anything larger than turning pens or short spindles - generally pretty useless. My first improvement would be to remove the "stock" 'too-short-necked' OEM light, and replace it with a Moffatt light (available from Craft Supplies, Packard, and other vendors) having a 24 inch flexible neck and quick release connector. This would be long enough (?) to be able to get around to the tailstock end of the lathe and illuminate the business end for turning bowls and vessels. Cost would be about $ 50-60.... Alternatively, I don't know if substituting the short flexible neck of the OEM light with a longer replacement flexible microphone support (Radio Shack? eBay?) would work as easily, but this might be considered too.
I certainly wouldn't mind owning a Jet 1220 as another mini-/mid-sized lathe - Definitely thumb's up!
Happy Holidays!
Rob Wallace
>Rob Like you I use my jet for demos, at least when I had one. I now have another with a bad motor so I'm making it a project lathe to see how I can improve it. It is a 1014. I'm going to put a 1 horse or 3/4 horse 3phase motor with VFD on it. I'm also thinking of changing the spindle to 1 1/4x 8 so it will match my other lathes.
Although I'm looking at the Jet and new Delta I still have to realize that I'm getting older and hogging a 100lb lathe off the truck is a consideration.
Re: Jet 1220 lathe light *LINK*
>I belong to the Nova owners group an one of the members built a stand for his 3000 an used Mic tubing it can be bought in 6" 13" 19" lenghts5/8" thread on both ends so they can be jointed. His set up look great so I think I will order some of this tube. The site is below if I can get it to post. Do a search for mic mounts and accessories.
http://www.samash.com/webapp/wcs/stores/servlet/topCategories_-1_10052_10002
Oops to long
>Its to long just do search on the Site..........
Lan Brady
>Gordon,
Use an appliance bulb in the 1220 lamp. It is much shorter and is shielded properly.
Lan
Re:Light extension
GalenV
>Bill:
About lost this message! That looks like a good idea as I still had not found a good alternate. Saved the web site and printed the item.
May try the local music store and office supply to see if they have here in town.
Galen
Gordon Seto
>I was using the safety bulb from Lowes that Mark Sfirri recommends. This bulb has a membrane over the glass; all broken glass will be captured inside the membrane when it breaks. It still needs a guard IMO.
Gordon
Rob Wallace
Re:Light extension
Rob Wallace
>Galen:
Try Radio Shack......
Rob
Bill Blasic
Re:Light extension
Bill Blasic
>I use the appliance light and have had no problem but the light itself needs to be at least 6" longer to be of any real use.
