Re: Segmented turning question
mfoster
>Malcolm Tibbetts' book is the best book on segmenting, in my opinion. You can mix and match woods, but it does require some special attention depending on the combinations. Try to avoid gluing a lot of oily woods together, as the oils tend to weaken the glue joint and gluing these woods together can be a bit of a challenge. Helps to roughen the surfaces with sandpaper before gluing and you can also wipe the surfaces with a solvent such as acetone to remove the oils.
Sanding presents different problems. One is the mixture of different colors as you mentioned, the other problem is the different densities.
If you really sand segmented pieces a lot that have different densities of wood, you will abrade the softer wood faster than the denser wood, winding up with depressions in the softer woods. Best cure for both problems is to do the best you can to get a clean surface off the tool. Sharp tools and shearing cuts. One trick that I learned from Malcolm, and which I was using today, is to use a cabinet scraper. A sharp cabinet scraper will help fair the curves and leave a nice surface requiring minimal sanding. You can sand pieces with different colors judiciously.
Another thing to consider is finishing. If you think a wood may bleed color (pernambuco or bloodwood for instance), it doesn't hurt to use a sanding sealer first. Dewaxed shellac is best for this.
Hope this helps some
Mike
