Bandsaw safety
keith tompkins
>The recent post concerning chainsaw/bandsaw safety prompted me to post this illustration. Many turners get into trouble when bandsawing blanks, and I believe this shows the most critical area where accidents happen. In the drawing the blade is cutting across the grain, and will cut freely. As the blade approaches the area highlighted by the red arrow, it will be meet more resistance, as it is now ripping, cutting into end-grain. At the same time, the blade is getting dangerously close to the edge. At this point, several things could happen....the blade could follow the grain, and drift outside the blank, causing the blank to suddenly lurch ahead. If your hand is in front of the blade when this happens, you are in a world of trouble. The key to using the bandsaw for cutting blanks is: Always use a sharp blade, a dull blade is an accident waiting to happen. Always plan your cuts: When I cut blanks, my left hand is already BEHIND the blade when I reach a dangerous spot, if I slip, my hand is already behind the blade, and there is no danger of cutting myself. Be sure your saw is adjusted properly, guides and tension are up to specs. Set up a "red" area, where your hands never are allowed to be in front of the blade, and never break that rule. Last, be sure your blank is as flat as possible, avoid unsupported cutting. I believe a broken blade is far scarier than it is dangerous...a broken blade on a 36" saw will scare the daylights out of you, no matter hom many times you experience it...be sure your guards are in place.
As far as chainsaw advise, keep your left elbow LOCKED, and your thumb facing down, wrapped around the handle. Never sight down the bar. Your reaction time is not quick enough to stop a kickback, a relaxed arm position, with a bent elbow won't allow you to stop a kickback. Plan your cuts!
