>I am looking for something to jazz up some rather plain birch bowls. Got some water based dyes from Craft supply. No instructions came with them. I know I have to mix with hot water. Anything else I should know? If mixed in large quantity, quart or half gallon, will they have a decent shelf life? Any special ways to apply?
>I've used water-based aniline dyes quite a bit, mostly for furniture. To date, I've usually sprayed it, but I have brushed it on with a foam brush, too. The key is to get a good soaking coat on, then wipe it down. You can find instructions for the aniline dyes on the Lee Valley Tools website. One thing to keep in mind is that these dyes raise the grain on the piece. To minimize that, you can water soak the piece first, so that the grain raises. Let it dry, then sand it down. The dye will then raise it much less.
>The water based dyes I have used are Reactive dyes. These are primarily used by the fabric industry and are known for being light fast.
The mixed shelf life is a few weeks. I mix the powder with tap water at room temperature. I mix with a toothpick and a cap full of water.
Dye can only make wood darker so don't look for bright colors on dark wood. Also know that most woods darken over time which will darken the dyed areas.
Be sure to raise the grain before applying the water based dye.
>I mix the dyes as I need them, and just eye-ball the amount of powder and water. Too weak is better than too strong - you can always apply another coat of dye, but you're pretty much stuck if the color was too strong. I tried mixing and storing, but life happens and two years later I still hadn't used the dye. Now I mix as needed.
I've wiped, brushed and sprayed them on. Experiment with some scraps first. Raise the grain and sand before applying the dye.
>I usually mix them with isopropyl alcohol (the ethyl alcohol dries to fast for my taste). I usually mix them in old Classico spaghetti sauce jars (because they have the measurements on the side and I have them). That way I can sort of get a rough idea of what strength I am mixing them to.
