Awesome new toys
Awesome new toys
Awesome new toys
mfoster
>I have had the Hunter #1 for a while now, but only really tried it on one small hollow form. I got a Hunter # 5 about a month ago and it sat on a bench till tonight.
I have been working on a large segmented piece for a while now, and it is finally stacked and in the turning phase. This piece will be about 18" in diam. and almost as tall (open form). I like to stack the piece and keep the walls as thick as I can to help reduce vibration while turning such a piece (especially at the rim). When I was getting near to turning this piece, I realized that I would be reaching way over the tool rest and flex in the shaft of my Jamieson could become a problem. I wound up talking with Lyle, and he highly recommended his Jumbo bar. Well, I got this for Xmas (from a not so subtle hint to my wife).
I was a little reluctant to try learning with a new tool on a piece of this scale. I have used hook tools and the Termite, so I thought I'll go easy and give the Hunter's a try. I started the process with the #5 at the rim and worked in. Turning with the #5 was a dream. Nice clean cuts and almost no vibration (I have a large heavy duty bowl steady which helps as I can get the 3 wheels supporting the bowl almost to the rim). I switched over to the Hunter #1 in the Jumbo boring bar and found this combination to be just as nice as what I found with the #5. I quit tonight when I was reaching 10" into the vessel, and still felt that I was getting almost 0 flex/vibration from the Jumbo bar. I have 5 or 6" more of reach till I get to the bottom of the vessel, but expect no real problems.
I was duly impressed with all the above tools. Definitely worth getting them. The Hunter's are great tools, and have the potential to become a tool of choice for me (for hollowing). The Jumbo boring bar is something I should have done a long time ago. I have done other large pieces using the Jamieson system, but probably pushed the tool further than I really should have. Turning tonight was Sweeeet!
Mike
Re: Awesome new toys
Dave Peebles Lyons, Ohio!
>Congrats Mike,
It sounds like it was a good day in the shop... Ahhh life is good with quality tools.
Best wishes,
Dave
check out my video if you haven't already  *LINK*
http://www.youtube.com/watch?v=UHxV1VkcBPE
Re: check out my video if you haven't already
mfoster
>Thanks John,
The video was helpful, but I picked up the use of the tool from what you posted in writing earlier in the forum and a little experimentation. I find using the Hunter tools very similar, even a little easier, than others I have (like the Termite and the Proforme). I see now why you have been touting their benefits.
hunter vs termite
>I found the same thing - the Hunter is easier to use than the the Termite (and works better, cuts cleaner and easier, doesn't clog, requires no sharpening). I think I have most of the sizes but the #5 is my favorite. Perhaps it was familiarity with the termite, but the Hunter felt natural to me the first time I picked it up.
I'd give away the Termite but the handle is useful. I wonder what I can make from the three cutters.
