Finish for Cocobola
Finish for Cocobola
Finish for Cocobola
BobM
>I just finished a cocobola finail for a hollow form that I made. I used Deft Spray Sanding Sealer and Gloss lacquer on the Maple hollow form. Will that same finish work on the cocobola or should I use something different?
Re: Finish for Cocobola
>Bob,
I've used lacquer as well as shellac friction polish. One guy told me he uses CA glue on small pieces.
One thing - I WON'T use oil again. I made two pieces once from the same piece of wood, used shellac friction polish on one and watco oil on the other. After some months the one with oil was visibly darker than the other. After a year, it was as black as ebony while the other still showed most of it's original figure and color. Maybe the blackening was due to something else, but I did not repeat the experiment.
Michael Stafford
>If very finely sanded, i.e. no visible scratch marks, about all you need on cocobolo is a little wax. However if the piece is poorly sanded you will see every scratch mark highlighted by the reflective wax surface. Cocobolo and some of the other highly dense fine grained woods have to be sanded at least to 600 and frequently I sand them to 12000. On my boxes I sand the wood using wax as a lubricant and clean it off between grits to remove any stray pieces of grit that may have come off the paper.
Bob Ingram
>I have had good luck with a cheap product called "Scratch Out" from Wally World...(in the car wax section) cost les than $3.00
Allen Neighbors
>I have a Cocobolo hollow form that I finished with lacquer. After 4 years or so, it's still got that beautiful color, and hasn't darkened that we can tell.
Usually, a wash-off with lacquer thinner, before applying the lacquer, will take the oils out of the surface wood enough to allow the lacquer to cure just fine.
>That's good to remember. I finished some cocobolo bottle stoppers with just fine sanding and polishing on the Beale, rub on a little Renaissance wax, and they seem to have held up well.
Re: I've tried many different finishes ....
Jamie D
>...on cocobolo pieces over the years, and decided that a very well sanded surface finished with a wax buff is the most trouble free and attractive method to really show off the wood's beauty.
