Need help purchasing Airstream AS400
John Scheideman
>I decided to purchase the Airstream AS400 respirator and know that some of you have been using it. I would like to know what you would suggest that I get with it.....extra filters, visor overlays, etc. I'm not familiar with how long the filters last or what I would soon need to buy after my original purchase. Recommedations would be appreciated. Thanks.
JOHn
Re: Need help purchasing Airstream AS400
Steve in NC
>I purchased mine from Airware America about 6 months ago and now use it every minute I am turning. I purchased the basec untit with the smart charger and 2 packs of overlays (10 each). The smart charger is a must if you wat to save your expensive battery. I change the overlays as neeed. I have not yet had to change the main filter. I blow out the prefilter regularly and reinstall.Good luck with your purchase.
Steve
Jim Sebring
>I don't have any experience with the newer Airstream products, but I have been using an Airmate 3 (pictured in Raffan's book "Turning Wood") since 1992. It has not had heavy use, but has served me well for a long time. I use it whenever I'm sanding at the lathe and when I turn dry wood. I'm very susceptible to dust, so have a Jet air cleaner hung from the 9 foot ceiling, and also run my Delta dust collector with 1 micron bags while making dust.
I've replaced the face shield on the Airmate 3 once or twice. The Tyvek chin skirts get dirty so needs to be replaced once in a while. The overlays are very worthwhile. They keep most of the face shield from getting scratched.
I've only replaced the filter a couple of times. I use the shop vac to clean it whenever I feel like it. Since the belt unit is behind me when I'm turning, it doesn't get a lot of dust directly on it. My helmet came with a cup-shaped air flow testing device. In use, it's placed in the end of the hose and the fan is turned on. If the cup floats up to a scribed mark, the air flow is fine.
I had the original 1992-vintage NiCad battery pack rebuilt at Batteries Plus a couple of months ago because it wouldn't run long between charges. The run time on these batteries is exceptionally long - upwards of 6 hours.
I have the following spares on hand: filter, battery, overlays, Tyvek skirt. I bought the spare battery in 2005 just because the original was pretty old. At $100-125 new, I've decided to have the packs rebuilt in the future. It cost me $32.19 to have the old pack rebuilt!
Sorry for the long winded response, but my experience should give you a good look at what you might expect from your new 'air hat'.
Merry Christmas.
Fog Tanner
>I have been using the AS400 for several years now. I don't turn anything without it. Onced you start using it, it is really uncomfortable without it. A "normal" face shield just seems ackward, plus it gets dusty on the inside. You onlt have to wipe off the outside of the Airstream. I know my eyes and lungs are a lot happier now.
I bought the smart charger, which is a good investment for rechargable batteries. I got mine from Airware America and they had a "starter" package. It contained another filter, prefilter, and overlays. The price was less than buying them seperate.
You need overlays. You can wash and/or blow out the prefilter. I change the main filter when the airflow drops. I also run my Cyclone when turning anything dusty, not just sanding. This probably helps my filter life a bit.
Good luck with your purchase,
Fog
John Scheideman
>Thanks for all the responses. I did not see a starter package on their website but will try to check into that. I am definitely excited to buy this. I had the old Rachel, which I used for years, and liked it but this one looks like the best respirator on the market. one last question....would you say that you change the main filter about once a year or more/less often than that (assuming that you use the respirator quite often)?
John
Fog Tanner
>There is an "airflow guage" that comes with the AS400. It is a piece of poster board with a certain size hole in it that fits the air intake. If the "guage" will stay in place then the filter is good. If it falls off then you replace it. Its a good idea to check it once a week or if you can start smelling the wood. When I turn Cedar, I can tell it is red but can't smell it. When I start to smell it then it is time to change.
As I mentioned, I run my Onedia while turning. That picks up most of the dust, so my time may be different than yours. It will also depend on how much you use it a week. There are times when I am in front of the lathe for 13 hours at a time (like today) and others when I would be happy to spend 13 hours in a week (like next month). 13 hours is pretty much the upper end of the charge - with a few coffee breaks and rest cycles. Also doesn't hurt to put it on change while you are drinking coffee.
Fog
John Scheideman
>Thank you so much for your help...
John
