>I'm thinking of adding some burning designs to some of my work. No, no, Jen, Carole--don't get too excited; this would be to FLAT work. lol. My question is: What burning tool to get? Are they all basically the same? Are some junk? Are there different diameter points or does 'one size burn all'? Will I find them at a Home Depot or Lowes or do I need to look online? What else do I need to know about them or caveats in using them?
Thanks in advance. And a very Merry Christmas to all.
>Hi Joanne, I always recommend the Burnmaster unit. You can find it at woodcarverssupply.com. It's well made, reasonably priced, can take any of the commercial pens available on the market no matter what plug they come with, and if the unit shorts out for some reason it has a built in breaker. If it trips you just reset it by pushing a button on the back of the unit.
The 'starter' pens I recommend are made by DetailMaster (also found at Woodcarvers), and include the 10A pen for outlining, drawing straight lines, and some shading; and the 6A for various texturing. As you try out different designs then take a look at some of the other pen profiles and see if you'd like to try them too. One point to mention. When you get the 10A, sharpen it using a fine stone, and then strop for razor sharpness (then just strop to touch up when needed). You want a combination of cutting the wood fibers as well as burning them to get nice, clean, crisp lines.
I am just down the road in Wrightstown, I have an Optima from pjl industries, which is a great machine. If you would like, I would let you take it for a test ride. I have about 8-9 pen tips for it. This would give you a good idea as to what you want out of a burning outfit. If this interests you, let me know.
>Thanks Molly! I take this as sage advise from someone I consider one of the burning gurus or mavens here. I assume being able to control the temp or intensity is important as different tips or woods have different requirements. Or is the temp more of an issue for how dark a burn I am looking for?
I have both the Optima and the Burnmaster and like them both. You can get the Burnmaster at www.landingcrafts.com for a really nice price. My friend Amy, who Weston and I stayed with in Washington D.C. before we came to your place, owns that company. Drop her an email off the website and tell her I sent you :) I really like the Optima pens. A lot depends on what you want to do when it comes to choosing the different pens. I would highly recommend the pens with soldered in tips and not interchangeable ones. There's always a chance for a loose connection with those. The Burnmaster comes with one or two ports. I have the dual, however only one will be hot at a time. I'm not sure what the advantage is, I guess it's just nice for lazy people like me who want to have two pens ready and waiting.
We expect to see some burned wood in the near future!
>Yes, the temp is an important component and will vary depending upon the density of the wood, grain pattern, tip using, and effect you want to achieve in your texturing or design application. I always recommend saving a little of your wood to practice on, in order to get the temperature adjusted right before touching your piece.
