Bandsaw Tuneup
bowlman
>Recently I have noticed some disturbing things going on with my Delta 14" bandsaw (with riser). This thing is probably 10 years old. New tires were installed last year. But here's the problem ... with a 1/2" or 5/8" blade installed, I can't get the upper guides close enough to the saw blade. I can get the rear thrust bearing up ok, but the side cool blocks are way in front of the rear of the blade, instead of almost touching and set just to the depth of the gullet. Gullet is completely exposed. Also, I have checked for co-planar and it appears fine, but, if I tweak it to get the blade where I think it should be, something binds. Any clues?
Also, I once saw a tutorial on someone's home page that had step by syep instructions on removing the top wheel, making some modifications, etc. Something about the tilt mechanism and the upper wheel housing. Ring a bell?
