cigar tree
James Pittman
>Has anyone turned catalpa [cigar tree] what do you think? I have a chance to get some free is it worth my time? Thanks Jim
cigar tree
James Pittman
Re: cigar tree
arkie
>Lighter weight, porous grain, marked hardness difference between winter wood and summer. It takes a little extra care, but I think it's worth it. It resembles butternut and is used as a substitute for that by carvers.
Re: cigar tree
Carole Valentine
>It can have spectacular chatoyance or it can be really drab. I have had both. As was said in another post, it is soft with a marked difference in hardness between early and late wood so care is needed to avoid ridges from sanding.
Re: cigar tree
John Jordan
>At the risk of repeating myself as I'm not sure my responses are appearing- in addition to the answers you have gotten, catalpa is extremely stable, very little green to dry movement.
It also often has caterpillars that are primo bluegill bait.
John
Re: For ice fishing??!! That's just an .....
Jamie D
>..excuse to go drinking!!! (;-D)
Re: cigar tree
terry quiram
>James
Grab the Catalpa for the following reasons. It is very stable and will store in log form quite well. Be sure to anchorseal the ends. You will learn what it means to keep a sharp tool. You will learn sanding proceedures based on the softness of the wood. You can rough turn the wetest wood and set it out to dry right off the lathe. You can make a huge bowl that doesn't weigh very much. Catalpa can be very dramatic if you get some with curly figure.
Terry
Re: cigar tree
Dick Hines
>I have heard that if the bluegill find out you have catalpa worms in the boat they will jump right in you cooler after them. You don't even have to use hooks.
Re: cigar tree
George Balock
>I've had some great catalpa with birdseys in it. Keep it.
Re: cigar tree
keith zimmerman, Normal IL
>Grab the catalpa Jim. I love the open grain of the catalpa. I like to dye catalpa, then apply liming wax to fill the grain. It creates a unique look. As others have stated, you will learn the benefits of sharp tools when turning catalpa.
keithz
