REAL MILK PAINT
If you can't laugh at yourself......
Ray Binnicker
>Some on you may recall me posting about going to pick up my new PM 3520B and then posting about the warning of testing one out. Well, this is story that must be told:
The un-packing, and set up went without any problems. I had all day so did not get in a hurry. I had already purchased the 220 plug plus a short piece of 12ga wire and a male and female plug to build a short extension cord. That went pretty well, considering my electrical skills. I thought I heard a soft drum roll off in the distant as I plugged the last plug in, looked at the lathe and there was a small red light showing the display. Success, right? I pull the on/off switch out, and nothing happens. I've got power, there is red light; I push the on/off switch in and pull it out again, nothing..... It has to be something I did wrong, but what, the red light is there, this is my luck, a bad lathe!!! I sit down on the stool I had nearby and start thumbing through the manual. I look up at that red light shining and then I look down at the speed control knob; you don't suppose I asked myself. I pull the on/off knob out and slowly move the speed control knob; low and behold !!!!
Don't tell anybody, ok.
Ray Binnicker
Re: If you can't laugh at yourself......
Your secret is safe.
Steven Kubien
Bob Ingram
>Must be the weather,
Two times, (Today) I re-pulled the on/off knob to make it go faster!!!
It did not! so.... turn the other knob?
Brad Vietje
And here's another laugh...
Brad Vietje
>Ray,
I have the same lathe, and you can bet I never did that. Just wait 'till you put your favorite gouge to a piece of wood, and son-of-a-gun, it won't cut. Then you re-sharpen or hone the tool, and DANG!, it just won't cut! What the...???
...then you remember the last time you used it you were sanding a piece in reverse. Yup -- been there ;~)
Congratulations on the new lathe!
Safe spinning,
Brad Vietje
Newbury, VT
>Wait till you try to turn on it and your tools won't cut. Yep, you left it in reverse. Where I teach they only have the 3520's and several times I've had a student tell me the lathe wouldn't work. We've had problems with the circuit boxes attached to each lathe so I always look there first and then discover they left the speed knob down.
Jesper, Denmark
Jesper, Denmark
>How are you with remote controls for the TV and programming the VCR?
>Oh don't get me started. We just got Dish TV and of course a remote control with more buttons than a 747. Not only that but they often have to be pushed in a certain order or they send you into la,la land and you almost have to turn the set off to get back to normal. I'm tempted to go back to rabbit ears and 3 channels.
robo hippy
>Reminds me of the time when I couldn't get my new chain saw started. Pulled for a long time before I discovered that I needed to hit the on button first.
robo hippy
