>I know you can order premade wire burners but I really have nothing else to order now. I think I have read in several places you can use metal fishing leaders or maybe nickle wound guitar strings.
>I've played with a lot of stuff. Most wire works, some won't or require extremely high speeds. I somehow lost the 2 had been using for years which were guitar strings so I grabbed some copper wire I had and now I'm using that. Copper wire doesn't work as well on the extremely thin lines because the thin wire will stretch and break. Guitar strings are very strong and come in sizes from .009" on up.
for really fat lines you can use the edge of formica and for really fat lines or burning whole areas use a piece of corrugated cardboard folded in half.
>Plain old black iron wire from the hardware store works as well as any other wire. It will eventually break from the heat stress, but it is cheap, and you can get a lifetime supply for about $1. It may be a bit higher now because I am still using the same rolls I bought 10 years ago.
>...out on the farm, but most bailers now use heavy twine instead. Most any wire of suitable size will do, just don't wrap it around your fingers or hand.
>I like to use the counter color chips that they have at the big box stores. Color does not matter. They are free and when you use them you don't have to figure where you are going to put the hot wire.
The burn lines may be bigger than you want then you will have to with wire.
>I don't like the effect of the larger wires, at least for smaller work. I have a bundle of .018" galvanized steel wires pre-cut to 12", made for tying tags onto equipment, sold in safety supply stores. Thin wire is also sold in hobby stores.
One thing - after a bit of use, the wire gets coated with carbon and such and the friction is reduced. If it quits burning easily, an easy fix: grab some 220 or so sandpaper and run roughen the wire surface. It seems to work regardless of the orientation of the scratches. I have to dress the wire repeatedly.
And for Jamie - you can still buy soft iron bailing wire - I use it a lot around the farm. It's way too thick for the lathe (for me).
>I went to a music store and asked for a set of the old strings they had removed when restringing guitars. This gave me plenty of material for six sizes of wire 'burners'. They just throw them away. Coyne
