Gold Leafing
Don wilcut
>I want to do some Gold Leafing and need some instuctions. Anyone?
Don in west TN
Gold Leafing
Don wilcut
Don in west TN
Re: Gold Leafing *LINK*
>If you ask Mr Google nicely, he will provide more than you can read in a week! Instruction, tips, youtube videos. The first link that came up, below.
http://www.woodweb.com/knowledge_base/A_Little_Abo
Re: Gold Leafing
Don wilcut
>Thanks John. Looks like that is exactly what I need.
Re: Gold Leafing
>Don You'll get a lot of info that scares you and makes you think it's incredibly difficult. It's not. Now I will say there is a whole lot of difference between the way the average turner does it and the professionals. So you can go as far as you want. Start easy. Start off with the fake gold leaf or silver or copper leaf. This gives you a feel for the process. Then when you get your confidence up you can try the real gold leaf.
Hobby lobby has a kit that's pretty simple to use. I'll bet you can find kits just about everywhere. Follow the instructions and you'll be fine.
Re: Gold Leafing
Don wilcut
>Thanks John. I'll follow your advice and someday post something.
Re: Gold Leafing
Chuck Engstrom
>I'll pitch in here with some additions to the article cited below--
The sizing discussed in that article would be an oil-based varnish such as McCloskey's Man-O-War or the like. Gilding supply houses have fancier stuff formulated specifically for gilding and rated as four-hour or twelve-hour varnish, meaning basically that the varnish has to dry four, or twelve, hours before it's ready for the leaf to be applied. McCloskey's I'd guess to be ready at four to six hours, but I've never actually tried it. And I'd say that tacky is not quite the term I'd use for judging its readiness -- the standard test I was taught is to drag the back of your index finger very lightly across the varnished surface; if it seems to stick, the vanish is still too wet, if it slides freely, it's too dry and you have to revarnish...you want it to just barely tug at your skin and then let it slide, sort of skitter across the surface. Not easy to describe but if you keep trying it every half hour or so you'll get to it eventually and sort of know it when you feel it. I had the best results with twelve-hour varnish since it would stay in the proper state longer than four-hour and harden a little better once I was finished.
Gilders use a flat skimpy looking brush of squirrel hair to pick up and move around the sheets and pieces of leaf, and it's hard to imagine doing it any other way. I don't think you'd have much luck just trying to pick it up and move it with your fingers. Once you lay it in place, you want a very soft, fluffy brush to help press it into the surface nooks and crannies, and I've found perfectly useful ones in the make-up aisle of dollar-type store, much cheaper than the purpose-made ones from leaf supply houses.
Gilding is very peaceful work -- you can't rush the process or get even a little bit hasty in your movements, and a sharp exhalation of breath can send sheets of leaf flying all over into little bitty fragments. With gold above $850/oz, it is precious stuff. Put some Gregorian chant on the CD player to get you in the mood for working a process largely unchanged for hundreds of years. And don't drink too much coffee before you start.
Best--
Chuck Engstrom
Re: Gold Leafing
Bill Howatt
>And since you can push it into nooks and crannies make sure your smooth surfaces are indeed smooth. Like any other finish, it doesn't hide flaws, it usually makes them more obvious.
Bill
