Candlestick
Candlestick
Candlestick
>I am presuming it is mahogany. I put it next to a cherry box as an example. Turned the cylinder and the tenons on both ends - also turned the "candle cups". It is "reversible" and will take either 2 3/4" or 3" pillar candles.
Re: Candlestick
Re: Candlestick
Don Emmerling
>Hi JL,
It is an interesting piece. Did you do the spiral work yourself?
Keep up the good work.
Don
Re: Candlestick
Re: Candlestick
>Don,
Yes. I drew a "rectangular" grid on the piece. "Vertical" lines every 90 degrees and "horizontal" lines every 1.5". Hand cut the diagonal with a dozuki to ~1/4" or so. Rasped out the cove with a file and a microplane rasp. Blended the curve. I then finished cutting the tenons.
