Wood Rot and Insects
Ken Oakley-Sunny St. Cloud, Fla.
>A while back someone asked how to kill insects in wood. I just read the following in an email I received from an antique website I subscribe to. I do not know if it works or not.
"There are two inexpensive materials that kill rot and insects--borates (borax-boric acid mixture) and glycol, available as auto antifreeze/coolant (use propylene glycol, not ethylene glycol, which is a dangerous chemical that causes damage to the heart, liver and kidneys). Borates and glycol are water soluble, so brush the chemical on the affected area and let it soak in, or if you can, immerse the item in a bucket of the solution for a few minutes."
Re: Wood Rot and Insects
>Using borates has been discussed and recommended by experts on the Wood Web sawing and drying forum, but if I remember as a way to keep insects from entering the wood. Dr Wengert maintains that none of the external treatments are sure death to powerpost beetles deep in the wood. They may chew their way around inside for years before coming to the surface. He suggests heating and holding the wood at a certain temperature (160 deg F?) for a sure kill.
>Ken, Google Nissus Corp. They make Boracare which is a borate solution suspended in glycol. Comes as a thick syrup that you water down and spray on the wood. They claim the glycol will penetrate to the center of a 12" timber. The stuff looks like clear Karo syrup. I have some and have used a little of it, but I have no real proof it works.
