Apple Wood
Apple Wood
Apple Wood
BradinOttawa
>I was recently able to get my little hands on a nice chunk of apple wood. The trunk is 3 feet long and 14 inches wide and is crotch wood. The downside is that it has been left whole for the better part of the year and from what I read the pith wood should have been removed.
1) Why should the pith would be removed?
2) Given that the wood is crotch wood and seems to be fairly twisted... is splitting a bad idea? I have used a wedge and maul before and have them kicking around. (I don't have a chainsaw and I don't think I can convince the missus that I *need* one. I have never been known for my powers of persuasion!)
Any advice is appreciated!
Brad
Re: Apple Wood
Re: Apple
Barbara Gill, Remlik VA
>With the pith removed radial drying cracks are less likely to develop. Apple can be a little twisty when it drys. If you don't have a chainsaw and can't think of anyone who might have one, you could try splitting but it is iffy. If you have a bandsaw there are instructions on the internet and Fine Woodworking how to safely saw round wood. Without the proper precautions it can be dangerous to you and the band.
Is there a local tree service that might help you out if you showed up with it in your truck, or another turner close enough to help.
Re: Apple Wood
Steven Antonucci
Pith will cause cracking
Steve Antonucci
>if not dealt with properly. Apple is also pretty prone to cracking, so if it cracks, I'd expect that you probably didn't do anything wrong.
If it were mine, I wouldn't cut it until I was ready to use it, and then I'd use it all. Removing the pith will slightly lower your odds of losing whatever you turn to cracking.
Hope this helps
Steve
Re: Apple Wood
Re: Apple Wood
robo hippy
>Since it has been down a year, letting it sit a bit longer won't hurt it. Leave it outside and covered. Apple is really nice wood to turn.
As far as splitting crotch wood, forget it, almost impossible without a hydrolic splitter, and it wouldn't leave you with anything you could turn. Cutting it with a chainsaw is better. Don't cut down through the bottom of the Y, cut it through all 3 piths.
I don't think I have ever seen the main trunk of any tree that I have taked that didn't have some cracking off of the pith. This is why you cut that out whenever possible.
robo hippy
Re: Apple Wood
Re: Apple
Carole Valentine
>You are right about the "twisty" part, Barb. I have some pieces (they had been split off with a maul) that were given to me that had been sitting in a basement workshop for probably 20 years. They almost look like someone had started to twist them into rope!
Re: Apple Wood
Thanks All
Brad in Ottawa
>Given the advice I will wait until I am ready to use the wood. Also, given some time for sober thought... I will borrow a buddies chainsaw!
Brad
