16" chainsaw, 24" log question
wilbur
>A neighbor recently took down a tree. There are two log segments that she saved for me that are about 28" long, and 28" in diameter. If I have a 16" chainsaw, is there a way to safely cut the log into two halves lengthwise? I've used a chainsaw a few times before, but never on anything that was bigger than the length of the chainsaw.
Re: 16" chainsaw, 24" log question
Carole Valentine
>I'd probably call a friend with a bigger chain saw! LOL But then I am somewhat of a chicken when it comes to using a saw. I don't like burying the tip of the saw. Mine is an 18" and I don't normally try to rip logs more than about 15-16". I will crosscut larger by cutting, rolling the log around and cutting again but I don't even really like doing that.
Carole's got it right!
arkie
>While I'd not hesitate, I've been using a chainsaw over 30 years. I've never cut myself yet, but I'm still cautious. There's ways of doing it, and safely (a relative term) but none I'd reccommend to someone who has "used a chainsaw a few times."
No amount of any kind of wood is worth risking your health. Get a friend, or pass.
>Wilber,
Making a cut like that can be perfectly safe. I do plunge cuts and buried cuts all the time as do the pros I've worked with and read about. A plunge cut is when you plunge the blade directly into the side of the wood. The fearsome rotational kickback comes from the upper quadrant of the tip digging . For the cut you mention, if you angle the back of the saw slightly back from the tip the upper part of the tip never touches wood. The second kind of kickback can still occur if the wood pinches the blade, but this should never happen on the kind of cut you mentioned.
HOWEVER, if don't have a lot of experience with a chainsaw, it would be best to get someone else to cut it.
Cutting with the grain is a little slow. It makes long shavings which can quickly clog the saw. Sometimes it's easier to start at the end and rip cut straight across - this makes dust instead of ribbons. Cut as deep as the saw will go, all the way to the bottom (angling the saw back from the tip a bit), then walk around and cut down the other side.
Another thing you might do is a lot safer and doesn't use any gasoline: split it down the middle with wedges and a sledge hammer!
BTW, the plunge or "bore" cut is the way loggers use to cut large trees close to or even larger than two bar lengths. All big trees scare me and I hire someone to put them on the ground.
Dick Coers
>Yup, I do it all the time. If you really want some accuracy, snap a chalk line along the log, then use a level and mark verticals on the ends of the log. I almost never stand the log and cut from the end because this really requires a rip grind on the chain. Plus that type of cut is really slow. I usually have the saw rocked forward or backwards at a slight angle. A level saw has a tendancy to get unstable and hop around a little.
Brian Hahn in SW Wisconsin
>I mark the log and slice in from both ends at an angle. I usually have to pause every minute or two to clear the shavings from the saw. Use wood chunks under the sides of the log to keep it stable and raise the log off the ground so you don't cut into the dirt or driveway.
Here's a picture of how I do it with an electric chain saw.
Barbara Gill, Remlik VA
>I make cuts like that all the time too as I use a 16" bar. In the sawmill I sometimes have to cut notches out of large logs so the mill can pass and anything larger than a 16" bar is too awkward. But I have been using a chainsaw for 23 years.
I agree though. If you are not real proficient and don't feel comfortable get someone with a larger saw.
Lyle Jamieson
Lyle Jamieson
>Do not fear this type of chain saw cut, just respect it. Follow the rules! Dont get the tip of the chain engaged in the wood...ever. Look at Brians photo. See the handle is down. You can cut at this angle all day long and not get a kick back. Stand at one end of the log as brian is and start the cut part way, say one third of the way into the tree. Stop and go around the other end of the tree and start the cut down the same line as the first. This is critical, the cut from both ends must be stratigh on the same line. As the tip of the saw gets into the wood from the second pass, close one eye and sight down the curf of the saw cut to make sure it follows the line from the first cut. I have wished many times that I had an eye patch because my face gets tired of holding one eye closed to sight into the saw curf. OK, go down with the second cut about a third and stop and go back to the other end of the log and cut some more. Again sighting down the curf to keep both cuts meeting in the middle and ending up on the other side of the log with a single cut path on a straight line with one another. Keep your chain sharp and it cuts like butter. Lyle Jamieson
謝謝
wilbur
>Thanks, everyone!
I think what I'll do is make a starter cut like Brian showed in his picture, and use wedges and brute force to take care of the rest.
I (briefly) had dreams of getting a bigger chainsaw, but I really don't use it enough to justify it. :@)
and Always be aware..........
Ruth Niles
>of what "might" happen. I do these cuts, too, and they are safe if you are constantly aware of what might happen IF.......
Actually I do this with any machine I use and the chainsaw is no different. Don't be aggressive, the machine always wins.
The only way you get confident and learn how to do anything is to do it with care.
