Grinder High or low speed
spinner
>I am looking to replace my grinder with a Baldor grinder but before spending all that money can anyone give me advice on going with 1800 or 3600 rpms? 90 percent of my sharpening is HSS turning tools.
Thanks
Re: Grinder High or low speed
>My personal preference is for slow speed but Jerry Glaser said that a High speed grinder was the best speed for HSS tools. I just feel like the slower speed removes less metal and lets me have more control over the cut and consequently the shape.
Re: Low speed for sure.
Jamie D
Keith Tompkins
keith tompkins
>Sorry to be the odd man out, but I can't stand the low speed grinders...one of the schools I teach at has two variable speed grinders; students always are shocked when I crank them up full bore. The secret is a light touch, you can see and feel the difference on the tool edge.
Bill Grumbine - Kutztown PA
>I agree with high speed completely! I think you get a smoother grind, and with a light touch or a finer grit wheel, you won't remove more metal than you absolutely need.
John Jordan
>If someone lined up several good grinders with good wheels and the 1800 rpm baldor was in there, I would bet that's the one you would pick.
I've used hundreds, own half a dozen, and the slow baldor is the nicest to use, all else being equal. Having said that, any of those decent grinders with good wheels work just fine. smooth with a good wheel is most important of all, and if you use good wheels, you don't need to spend $100 for a wheel balancer, even on a cheap grinder.LOL
John
I agree
Brian Hahn in SW Wisconsin
>But then I learned how to sharpen with carbon steel on a high speed grinder. A light touch is the key.
Would you turn a pen using the lowest speed on your lathe?
Dick Hines
Re: I agree
Dick Hines
>I also have a high speed grinder. I put no pressure on my tools, just a light touch does the trick.
A light touch would be the way to go on a slow grinder too.
Re: The X factor is the skill of the .....
Jamie D
>...operator, and for an inexperienced grinder I recommend the low speed. High speed may be OK for those who have mastered the job, but as with most everything at high operating speeds, stuff happens too fast!
Concur
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I use an 1800 rpm grinder, and it seems just right. I don't see anything low speed about 1800 rpm anyway. I believe the more important question is what type of grinding wheels to use, how to clean and true them properly, and, possibly, how to balance them.
i like my belt driven 1400 rpm
robert davis
