>I have a blank for turning a bowl that is coated with wax. Hate to display my ignorance, but what's the best way to remove it? I assume that it would gum up my tools if I tried to turn without removing the wax. Thanks for any help. Hal
Don't worry about it, it won't gum up your tools. Just go ahead and mount the blank on your lathe and start turning. All of the wax will disappear into the shavings pile on the floor. Just ignore the wax as though it wasn't there.
>.....natural edge burl, and then a stiff nylon brush will remove the remainder. If it's a real pain, use a hairdryer to soften it up, then the nylon bristle brush will do the trick.
>Along with that, don't ever apply anchorseal to a bunch of blanks in an area where you will stand and walk. Spreading the dried drips with my feet lubricated the concrete floor with a wonderfully slippery waxy film. Now I need to keep the floor covered with six inches of shavings or sprinkle cat litter or put down more rubber mats or even [gasp] clean the floor.
When I have a waxed blank that I don't plan on turning immediately and want to dry, I (gently) hold the waxed edges to the edge of my band saw blade and scrape off the wax. Hope this helps.
