>Been a while since I posted so I checked the archives. I'd like to convert my non-VS Mini to VS. I couldn't find anything current regarding this conversion and haven't been able to Google anything up either.
Just hoping that someone has current information regarding this conversion including vendors, etc. TIA.
>Frank The only cheap way to do it is to sell your mini and by the variable speed. If I remember correctly the motor is $179 from Jet. You still have to buy the Controller. Looking at the Woodturners catalog there is only $100 difference in price new.
If you buy a DC motor and controller from Woodturners catalog you are looking at $579 dollars. It is a better motor but is larger and won't fit beneath the lathe.
Another option is a Variable Frequency Drive with a 3 phase motor. From Dealers Electric.com you can get a controller for $129. I didn't price the motors but I think you can get one for about $100 or so. You'll need some electrical experience to wire this up and the motor probably won't fit below the lathe.
>I don't want to derail your project, but I think this is one of those situations where the benefits may not justify costs and effort required. I have a Jet Mini, which I love, and have never felt the need for a variable speed drive. When you consider the limited range of what you can turn on a Mini, I find the speeds provided by swapping the belt from one set of pulleys to another to be more than adequate. I also have a Stubby and variable speed is an essential feature. Give this some serious thought before you spend a pile of money on an improvement that you may not really need. Others may disagree..........
>I use variable speed a lot in my turning but I agree with Barry. On my mini lathe I tend to use the same speed all the time. The only time I switch speeds is when turning bowls. I start with the slow speed and then change belts back to the higher speed and keep on cutting.
>I wouldn't turn on anything but a VS lathe. On the mini it will let me dial down the speed to sand which makes the paper last longer with less heat build up. I can dial it down to put a CA finish on pens, then crank it up to polish that. On the big lathe it lets me tweak a heavy blank a few rpm's to reduce vibration. All that said, I agree with John, sell the pulley machine and buy a new one. But if you really must, I think I have read on here that Penn State sells a conversion. I looked it up and it is on sale, but sure can't help with any quality issues.
>I forgot about that one. Thanks Dick. If anyone has any info on the quality of this kit I would love to know. I would hope that it's pretty decent but I've been looking at motors online for a while now and they just don't sell that inexpensively so it makes me wonder. I may just order one and see.
>I have been using the Penn State conversion for a year....works great, handles a heavy load (for a Jet mini)...I did not use the pulley that came with the kit...I put the pulley from the Jet motor on the new VS motor...I was even able to rig a reverse switch to the control box...great results...
>Several years back Mark Kauder posted his conversion using a treadmill motor. I have lost that info (computer melt-down), but it is probably available in the archives.
>Thanks very much for all the responses, especially the links to Penn State. I've ordered their unit for $120 shipped. I gave $250 for the mini from Woodcraft so this makes it $370 invested. I think I'm still ahead of the game......if the conversion works :>)
