When you are stupid you are suppose to suffer
Dick Hines
Dick Hines
>Ok I screwed up today. Getting out of bed does not count. Yesterday I roughed and cored a large piece of BLM burel In the 17" range. Today I was going to turn some pens of an order and when I tried to thke the chuck off it was stuck. I worked on it for while with no success. I set the spindle lock ant used a wrench. No luck. So I hit the wrence,no not with a hammer just my hand. Crack!!!! The spindle lock now is 3 pieces.
I orderd a new one. So the question is , how much trouble is it to remove the spindle and replace the spindle lock? I have lookde at the blow up drawing on the manual and it does not look to hard. Of course that's what I said when I was tring to get the chuck off.
The obly good thing is I can still use the lathe,PM3526A, It's just a pain in the butt to get chucks off.
Re: When you are stupid you are suppose to suffer
Michael Stafford
>Ouch, ouch, ouch! Patience is a virtue my friend....8-)
Allen Neighbors
>You shoud have first called Ruth Niles. :)
(Sorry, Ruth... couldn't resist!) :o)
>Dick,
They sell nylon washers, those prevent the chuck from jamming.
Gary in Zirconia,NC
>That is a very weak spot on that lathe. I broke mine and so have many other people. They sent me a new one at no charge and it was steel not cast iron like the original. I have had on problem with the steel replacement.
Wait A Second...
Barbara Gill, Remlik VA
>Why did the spindle lock break when you hit the wrench with your hand? I could understand if you hit it with a hammer, but your hand???
Dick Hines, man of steel......!
Michael Stafford
shop at 10 below zero?
Not as hard as that invisible wood you've been,
Eddie Pacheco; San Jose, Ca.
>Turning.
You're talking about the detented disk that is on the spindle, right?
The "A" model lathes had a cast iron plate for this. Later it was switched to machined steel and those don't break. I think, because you have to remove, the spindle, you should gotten a new set of bearings too. They are not too pricey. Keep track of or a good feel for how tight the castle nut at the rear of the head stock is. This nut is used to preload the bearings.
Good luck and please switch to naturally colored wood.
How's your hand?
Carole Valentine
Ruth to the rescue!!!!
Steven Kubien
>I am waiting for next time when she actually cracks the headstock casing.
Runnin' and duckin'
Dick Hines
Re: How's your hand?
Dick Hines
>My hand is fine. It's my pride that is hurt.
Dick Hines
Re: Wait A Second...
Dick Hines
>I had the spindle lock set so I could get the chuck off. I had a wrench on the insert. The wrench was made for the insert.
I could not move the nut so I just hit with my hand and the lock now is three pieces. It was not steel either.
John Jordan
>Wow, Dick. I hope you can get the part for free. Don't the PM have two wrenches?
I have a couple of suggestions for anyone with these kinds of issues, and after reading some of the responses.
Use the wrenches if its really tight. Lubricate the threads, and snug the chuck/faceplate up with the key and spindle lock, or wrench(es)-it will take the same amount of effort to remove it. Never "snap" spin it on. Don't use plastic washers as they compromise the joint and you may have flex and chatter on larger pieces.
Most of all, don't hammer with your hands-they're the only ones you have. :-)
John
Re: Ruth to the rescue!!!!......never again...
Ruth Niles
>Steve, I have seen the light! I now take great care not to get a chuck or faceplate stuck..........what a pain that can be. The only good thing is both Dick and I have expanded our knowledge of our lathes. I think I know more about the General than the tech guys in Canada! : )
Dick Hines
Dick Hines
>The part was not free but's OK. I just want to get the thing fixed. The trouble was the coreing of the big blank. I got a couple of catches and that just jamed the chuck onto the spindle.
I can still use the lathe. That is the most important part.
For the Terminally Cheap
Al Kapocius
>You can also cut your own washers from plastic milk jugs.
Al Kapocius
