persimmon boxes
persimmon boxes
persimmon boxes
>These are from the same stick of wood roughed out for box blanks at least a year ago and left to dry.
The first one is un-ergonomically shaped and would be challenging to open except for the whisper fit. A snapped fit like I saw on the Jimmy Clewes video would lock it closed forever. A shape like this might be good for hiding things from people with greasy fingers. I like the stepped inside of the second lid - I think I'll try that again but with more steps.
This wood cuts like ebony (of course) and needs very little sanding. These are the dreaded flat-bottom boxes. It sure is easier to make a smooth curved bottom. I ground a 1/2" Thompson scraper to do the insides.
JKJ in East TN
Re: persimmon boxes
Re: persimmon boxes
BobM
>Nice boxes! I think I like the squared off top box the best. I am just getting into making boxes and I see your point about the rounded top box. That was a good tip.
Re: persimmon boxes
You've been busy
Randy G
>Nice pics... all of em. I liked the shape of the square ish one as well. Looks like there's a slight curve in it, correct?
Re: persimmon boxes
Re: You've been busy
>Thanks, Bob and Randy. Yes, the "squared off" top is actually a very slight convex curve, but it doesn't show well in the photo. I should have placed a small backlight above or positioned a piece of reflective paper to add a highlight. The inside of the top is also gently curved to echo the outside.
Bob, if you do make a top that is difficult to grip, you can often design a finial or some top decoration that functions as a knob. A top that flares out is definitely easier to grip. I knew this one was contrary to accepted design suggestions, but I wanted to see what it would look like with the dome cutting through the grain pattern.
Randy, I have been turning a bit more since my rib injury is much better but the weather turned too cold to work on the new barn. I set up the photo tent the other day and took photos of several pieces I'd done over the last few months so that's why they are all coming at once! Hope it's not an overload.
Re: persimmon boxes
Randy G
>John,
That convex design is nice and very interesting that the inside of the box follows the same curve. Very nice.
Understand how injuries and life changes what your working on.. definitely not overload, enjoying seeing everything you've been working on
Re: persimmon boxes
Re: persimmon boxes
Michael Stafford
>Indeed, you have been busy. The squarish box is my preference both for ease of use and for shape. I think it is much more appealing to the eye. I am sure you are correct, the rounded top box would be a bear to open if it was a tight fit.
I will have to give you some lessons on cutting the bottom of the inside square. There are a few tricks to make it easier.
Nice looking boxes, John.
Re: persimmon boxes
Re: persimmon boxes
Ray Binnicker
>John K,
I like both the Persimmon and Cocobolo boxes !! I do prefer the square top Persimmon over the round top.
I've done the square inside and the rounded inside. I have had several ladies say they like the round inside bottoms best. It seems they can get a ring, ear ring or other small item out of the round bottom a lot easier. You can slide the item up the side rather than trying to pick it up.
Ray Binnicker
Re: persimmon boxes
Re: persimmon boxes
Jim Shaver - Oakville, Ont
>I love boxes!! These are awesome...
Nicer that my Wilson Pro Staff Persimmon's!!
take care,
Jim
Re: persimmon boxes
Re: persimmon boxes
Steve Russell
>Hello John,
Very nice looking boxes! I really enjoy turning persimmon, but don't get the chance very often. Thanks for sharing your work. Take care and all the best to you and yours!
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
