mini lathe
mini lathe
mini lathe
Jerry Gibbs
>I winter in a trailer with extremely limited space. I am looking at a mini lathe (not a short bed regular lathe) that I can easily put in and out of the storage shed or car. We have so little space I store stuff in the small suv. I want to make toys and other small turnings. I am looking at the Grizzly G9247. Has a 2.6 amp motor. Any comments re this unit? Also what about Grizzly accessories, especially chucks. seems there are plenty of accessories for the MT1. Jerry Gibbs
Re: mini lathe
Re: mini lathe
Barbara Gill, Remlik VA
>I don't know if they are still available but I have a Mercury VS lathe. It is a real nice lathe that isn't too heavy to pick up and move around. In the shop I keep it on an adjustable worktable. I have it mounted on a board which makes picking it up real easy. I am able to put it into the trunk of my car and get it out easily. I turned the outboard side into a sharpening station using the Wolverine base; there is a picture in Shop Shots.
I use a Talon chuck with it. The first chuck I bought for the lathe was a Compaq which was a total piece of junk.
Re: mini lathe
Re: mini lathe
>Don't know anything about the Grizzly, but I know a Jet mini is small enough to lug around and big enough to turn bowls, magic wands, boxes, pepper grinders, etc. I got one to carry around for demos and such and set it in the trunk of the car. You might find a used one in good shape - I recently bought a second one for $150.
JKJ in East TN
Re: mini lathe
Something to consider
davidwalser
>Jerry,
I can't comment on the Grizzly lathe you asked about. Grizzly makes some good products (although, in general, their lathes have not gotten rave reviews). My concern about this particular lathe has to do with its Morse Taper. If you have another, full sized lathe, it most likely has a MT-2, not the MT-1 used on the Grizzly. It might be a false economy for you to go with a MT-1 machine if it means buying new accessories to fit the smaller Morse Taper on the new lathe.
The "gold standard" in mini-lathes, the Jet, has a MT-2 in both headstock and tailstock. It comes in 10" and 12" swing versions. Most of us have a lot of accessories that use a Morse Taper -- drive centers, mandrels, drill chucks, revolving centers, etc. Together, these accessories may cost more than the difference in cost between the Grizzly and the Jet. Of course, if you'll be outfitting your mini-lathe with it's own set of accessories so you don't have to lug them between your winter and summer homes, this isn't an issue.
Re: mini lathe
Re: mini lathe
Scott Greaves in Blackfoot Idaho
>Funny, when I read your question, the first lathe to come to mind was a Mercury! But you'd have to be lucky to find one as they're not made anymore. The other one I thought of was the small Vicmark, VL 100. The Jet mini is a great mini-lathe, but it is larger and heavier than the two I have mentioned. I don't know about the Grizzly you mentioned.
Good luck!
Scott.
Re: mini lathe
Re: mini lathe *LINK*
>Are you sure they are not made anymore?
Mercury Lathe
Re: mini lathe
Re: mini lathe
Allen Neighbors
>The Mercury is still made, but is not available everywhere. I tried to get one when I was looking for a travelling mini. I ended up with a VL100 bench model which I mounted a 1/2hp reversible motor. It's now my traveller. I highly recommend it. It's a little more expensive than the Jet Mini, I think. But it's sure a precision made machine.
Re: mini lathe
Jet mini lathe
Jim(IN)
>I own a Jet Mini VS and as a newbe turner I have not been disappointed with it. As mentioned, you may(and someday will) want to graduate up to a larger lathe and caution you to look at a mini with MT-2 due to many accessories fitting it rather than MT-1. Watch for the sales this time of year, youmay be able to save a few dollars.
Good Luck
Jim(IN)
Re: mini lathe
Re: mini lathe
Jerry Gibbs
>Thanks for the input. Portability remains a key component of my decision. I am strong for my age, but as my wife reminded me when I pointed out some other tools that would last a lifetime, "you're already 63". Jerry Gibbs
