Bleg: Mirror blank size
David Walser
>I'm planning on making some hand mirrors ala John Lucas (and others who've posted here). I'm using 4" diameter mirrors. Any recommendations for size of the blanks for the handle and mirror body?
Re: Bleg: Mirror blank size
>My mirror bodies are 5 1/2" and the handles start out as 10" x 3/4 or larger. Be sure and leave enough room around the glass for wood expansion. I turn the opening 4 1/8" and then undercut the lip slightly using a detail gouge to give me a total opening of about 4 1/4"
I glue the glass in with Clear Silicone Caulking.
David Walser
>John,
Thanks for the help. One more question: How thick are your 5 1/2" mirror body blanks (rough size, not finish)?
3/4 to 1"
just curious
>Did you ever have a mirror break from wood movement? (Did you learn the hard way?)
Re: just curious
>No,I had the wood break. Actually it was a segmented piece. The gallery that I sell most of my mirrors in is very very dry. Gail called and said I had a mirror returned because the image was distorted. I told her that often happens with Ugly people. No seriously I got there and took the mirror and could not see a problem. The reflection in the glass was perfect. Well as perfect as it gets when I look at it. I turned it around to show Gail and guess what. The wood had seperated at the back in one of the joints. After that I started undercutting the lip to give more room for wood movement.
The reason I undercut instead of simply making the hole larger is that it looks better. I like the opening to be very close to the same size as the glass. Since I use bevel edge mirrors the undercutting only has to go a little bit larger than the glass and is tapered. I do this by using a detail gouge. I put the bevel on the wood with the flute pointed straight out toward the tailstock. Then I push it into the wood with a very slight twist of the handle so the bottom lip of the tool cuts the wood. This gives me the tapered undercut in one quick motion. If I'm doing a rounded edge lip I simply pull the handle of the tool toward me letting the lower lip shape the lip. This is a scraping motion but my detail gouge is quite sharp on the edges so it leaves a finish that can easily be sanded by 220 grit.
Re: just curious
>Thanks. I made some 3" mirrors and am about to make some with the 4" beveled mirrors. Stands to reason the larger pieces of wood would move more so I think I'll follow your advice.
BTW, I sent something your way Friday.
Question on finishing them?
>If you stain them or use wood that changes color when the finish is applied, do you finish the under side of the lip of the undercut? I have made a number of frames for mirrors and found that I have to finish the rabbet for the mirror because you can see it in the mirror. This may not apply to your case because the mirror is not actually in the undercut.
Re: Question on finishing them?
>Barry I do finish the first 3/8" or more because you can see that area. I usually put at least one layer of finish on the whole inside. It's just a thinned lacquer finish. Putting a thin coat on everything after sanding makes the initial spray coats build better so I don't have to spray as much. I do the same with Wipe on Poly but quite often don't thin it because it's already pretty thin.
