REAL MILK PAINT
Help with dust control
waltc
>I'm continuing to turn and to generate dust. I've been wearing a Trend Air Shield, but I'm unhappy with all the dust in the rest of the shop. I've spent some time thinking about controlling the dust, and I've come to some conclusions. I would appreciate feedback from those who are using dust control systems and have some experience with them.
My first step is to isolate the lathe, probably using transparent/translucent shower curtains. My shop is small enuf that I don't want to permanently subdivide it.
The dust remover has to be outside the shop. I am not willing to work with a roaring fan in the same room with me. I need to hear how the chisel is affecting the wood.
I don't need to connect any other tools to the dust collector. I don't need to collect chips, either, they can fall on the floor. Just the dust in the air. I live in a rural area, so that I can exhaust the dust outside the shop without alarming or upsetting the neighbors. So I don't think that I need bags to collect the dust , just exhaust the air and dust. I probably would run the system for 20 hours a week, max.
My thoughts are to find a fairly high capacity, low pressure exhaust fan, set it outside in an enclosure to reduce the sound, and use a fairly large duct into the lathe area of the shop, and a flex duct attached to a homemade hood behind the lathe.
Anyone tried this type of system and had success or learned some lessons that they would to pass on?
Thanks in advance for your thoughts.
Re: Help with dust control
Dominic in Bucks County PA
Contain dust at the source
>Walt,
I usually experience the most "dust generation" when I sand at the lathe. So I'm assuming that is the case with you. Your idea of enclosing your turning area with plastic is a good one. Before I rearranged my shop I used to use clear shower curtains.
To help to reduce (notice I said "reduce", not "eliminate") the dust I installed a 4" dia dust pick up at my lathe. At first I used a section of 4" thin walled sewer pipe and an old office chair for a stand. The positioned the pipe directly behind my spindle. When I sand, the dust gets sucked right into the pipe.
About 2 years ago I decided to upgrade and purchase a Dust Picker2 Dust Collection Arm from PSI. This has helped me out a lot since it enables me to more easily position the pickup closer to my work.
Still, when I turn particullary dusty wood, I tend to have my DC running, a dust maske on, and my Air Filter on.
I hope this helps.
See ya around,
Dominic
Re: Help with dust control *LINK*
>I think your biggest problem would be conditioning the great outdoors. I like heat in winter and air conditioning in the summer. That's why I have a cyclone.
To move that much dust, you've got to move a lot of air. If you are exhausting it to the outside, you are losing heat/cool. If conditioning the great outdoors is not a factor, I'd check some of the multiple speed exhaust fans. They are offered by the various industrial supply houses such as MSC. I've worked for a number of companies that have used them to move vapors and fumes. They should work for dust.
Exhaust fan
Wally Dickerman in Arizona
>If you don't have one, an overhead dust filter is a must for any woodshop and especially one with a lathe. Don't put it behind you as it will draw the very fine dust (the worst kind) right to you. You'll be surprised at how often you have to change/clean the filters.
I recently acquired a large dust hood with stand from Woodcraft. The hood is 12 x 16 and it can be moved up to practically surround the piece being sanded. It connects to a 4 in. hose. So far I like it. I can easily move it from the inboard to the outboard bed on my lathe.
Wally
robo hippy
>If you aren't worried about heat in your shop, then a dust collector or exhaust fan will work fairly well. Channeling the air into and out of your turning area will help also. I built an enclosed room, but the shower curtains will work okay. The newer dust collectors aren't that noisy, and almost as much noise is generated by the air moving through the ducts. I prefer the Oneida cyclone systems, and theirs are the best out there. The paper pleated filters are much better than the fabric bags, and they don't leak ANY dust. You can put the dust collector outside, and vent the air back into the shop by using a little extra ducting and putting the filter inside the shop. A hose at the lathe works okay. A bigger funnel type thing like Wally has works better. I mostly turn bowls, and when I sand, I have a hood made from a 55 gallon white plastic drum. I cut a bit off the end, and one side. I cover the end I cut off with plastic and I stand in front of the side I cut off. It goes up against the headstock, and leaves about 4 sq. ft. open, and the bowl goes inside. I can sand all day long, with no dust mask, and I get a bit of dust on my arms, and on my smock, but none on my glasses, or up my nose (and I have checked even after sanding a lot of black walnut). Oneway makes some thing similar, but costs a lot more. You can also buy 1/8 or 1/4 inch sheets of the same plastic and mold/cut/shape it any way you want. The more enclosed your turning area/lathe is the better your dust collection will be.
robo hippy
Jesper, Denmark
Re: What they said and.....
Jesper, Denmark
>I always thought that the clear plastic fork-lift truck doors used industrially would be a good idea to close-off a section around the lathe. You know, the 12 inch or so heavy plastic strips that hang down and overlap a little. They do not flutter about as much as the shower curtains and you can see through them.
Never got a round tuit, though.
>You did not mention a budget. Do you want a cheap homemade solution or are you planning to fore go the fun of building something yourself and spend the money?
You can buy what appears to the be the blower?fan from a dust collector system/cyclone and just let it blow outdoors. You would need a pickup duct for it. Or you could use the blower out of a furnace. Sometimes heating contractors will give you a used one.
Something to consider is that on cyclones, the debris does not go through the fan. It drops out and the air and maybe a little fine dust goes through the fan. On other systems all the debris goes through the fan. I know you are considering dust only, but anything that goes into the duct will go through the fan. I sucked up the long stringy curls from a day of green wood turning and they got caught up in my DC Impeller. Had to pull the inlet pipe off and pull them out. Would not have been a problem on a cyclone.
And the others are right. You want the air flow from behind you toward the inlet. Pull the fresh air past you and pick up the dust. The larger the pickup the more air flow you need to get the air velocity up.
