Have a question? Ask Woody!
Bandsaw blade *LINK*
Re: Bandsaw blade *LINK*
Re: Bandsaw blade
>I bent 2 of them. I do not suggest them for green wood cutting. They are fabulous for dry wood resawing. I use the cheapest blade I can get for sawing greenwood. No matter how careful you are you will eventually get a catch and it can bent the thinner flexible blades.
I like them!
James McClure
Re:It's very aggressive but works like ...
Jamie D
>... a champ when you have a saw with sufficient HP to fully benefit.
Re: Bandsaw blade
Ken
>I'v been using them and for about two yrs now and love em.I broke one (my fault) called and told em how I did it and they replaced it at no charge.Its a great blade and there service is great.One thing I use when cutting green wood is keep a reg old can of pam around and spray the blade on ocassion and it keeps it running smoother and holds off the rust.If you cut a lot of wet wood you want to spray some type of lubricant on the blade when done.
Ken
Re: Bandsaw blade
Ian
>i second what john said,
for cutting green wood cheap blades.
for precision work change the blade.
IAN
Rob Wallace
Re: Bandsaw blade
Rob Wallace
>Hi Paul:
I have been using these blades since they first came out, and I find they work really well - especially on green wood. I have one nearly always in my band saw (unless doing something special for flat work), and I re-sharpen (actually, touch up) the blade right on the saw with a diamond chainsaw sharpening "stone" in a Dremel tool. This simple procedure restores the blade to like-new performance, even after many blanks have passed through the blade. These blades have considerably more set than the "cheap" blades of similar configuration, and this makes a lot of difference. In a few years of using them, I've only snapped one of these blades (at the weld), and it was a quite old one at that. (I brazed it back together, re-sharpened it, and got some additional "mileage" out of it until I bent it "fatally", trying to saw a blank that was too large for my saw - my fault.....) I nearly always have another of these as a spare blade on hand.
Yes, they cost more, but in my opinion, it is worth it. Several other members of our turners group also use these blades exclusively, and the last time Highland Woodworking had free shipping, we put-in a group order for these blades.
Try one, and see for yourself - IMHO, it is a good blade.
Rob Wallace
Rob Wallace
Re: Bandsaw blade
Rob Wallace
>John:
Are you sure you're talking about the same blade Paul's asking about?
When you mention re-sawing, I think you're talking about the Wood Slicer blade that Highland sells - I agree - these are excellent for re-sawing of dry wood - I have one of these blades too. They are NOT meant for green wood sawing.
The blade Paul is asking about is very different from the Wood Slicer - I find it hard to believe that you had major problems with the 3/8" woodturner's blade on green wood.
Did you actually bend two woodturner's blades?
Rob Wallace
Re: Bandsaw blade,negative
robert davis
>i have two. the reason i have two is the joint on the first one was so poor it was not useable. they replaced it. thr second one was better bt bumps at the joint. will go back eo timberwolf ..never to stray again
