steel wool for finishing
ILYA Zavorin
>After applying several coats of a salad bowl finish to a bowl, I noticed that the finish both feels and looks uneven. Someone suggested using steel wool to smoothen it. What grade of SW should I use? Thanks much.
Re: steel wool for finishing
Ken Oakley-Sunny St. Cloud, Fla.
>0000,(zero,zero,zero,zero), 4/0
robo hippy
>I use the grey synthetic wool pads. No little bits of steel wool left on or in the wood to rust out later. I believe the grey wool is comparable to 000 steel wool. There are white (0000), red and green as well, but white is too fine for me, and the others are too coarse. I got mine at Woodcraft, but other places have them as well.
robo hippy
>I pretty much gave up most steel wool. I didn't like the shreddies. I use grey, maroon and white "scotch brite" pads.
Vince sent me a piece of
Allen Neighbors
>steel wool that was finer than 0000 to try. I like it, but I don't know what it's called. I plan to put some in my next order.
You might call him and ask about it.
Re: Vince sent me a piece of *LINK*
Cyril Griesbach
>Allen should have included this.
Vince's Woondnwonders
Re: I also prefer the gray Scotchbrite ....-
Jamie D
>...pads rather than 0000 steel wool, and you can mount them on a sanding pad holder(Velcro/hook&loop) and power buff very efficiently. The white pads have no abrasive and work well for buffing out waxed finishes.
Four-Aught
Brian Hahn in SW Wisconsin
>I use 4/0 (four-aught) steel wool. I like the way it smooths the surface, but it does shred. I've also used the non-woven pads ("ScotchBrite") and don't like them nearly as well. I've had trouble with them making grooves in softer woods and they aren't as consistently abrasive as steel wool.
Liberon steel wool is very good.
>If the surface is "uneven", fine steel wool might just polish the unevenness. I like to use fine sandpaper (600-1200, depending) after the finish to take out unevenness, then use another coat or two of finish and repeat if necessary. Then hit it with steel wool or the grey pads.
How best to proceed may depend somewhat on what you mean by "uneven" - bumpy, undulating, rough grain?
But for steel wool, Liberon 0000 is perhaps one of the better brands, carried by most of the woodworking suppliers.
robert davis
>me too jamie.
Vince Welch
>Hi ILYA ,
I too also recommend a scuff bright pads (generally the maroon color/320 grit pad) or my new Sia Wool product that Allen N mentioned. Either of these products will cut back or help even out you finish. I have samples of my New Sia Wool product if anyone would like a sample I will be happy to include a sample with your next order. Just let me know how I can help. Vince
www.VincesWoodNWonders.com
