Help with Finish Please, Olive oil question?
>I posted this on the flat side, but they are so busy making presents no one offered learned advice. I thought I would post it here since we sometimes finish bowl with olive oil.
I laminated a flat panel with a walnut ply on each side of 1/8" plywood. One side is plain and one is fancy crotch veneer I sawed myself. My son left a paper towel soaked in Olive oil laying around and the plain side of the panel got laid on it. I now have a dark splotch. The walnut is dark anyway and I wanted the lightest possible finish. What to do? I tried wiping it with lacquer thinner, did not help much. This will be the under side of a lid on a box about 8 by 12. Would you coat the whole side of the panel with the olive oil? Would you seal it with shellac? Was thinking of Deft lacquer as a finish? Help!
Re: Help with Finish Please, Olive oil question?
Ed Karch
>Thinking and guessing what I might try (on a test piece)reproduce the stain with olive oil, mix some Japan dryer with other olive oil in an attempt to turn it into a drying oil that would polymerize. This might stabilize the oil so it wouldn't creep out under your finish. You could then seal with shellac and over coat with lacquer. This would give acetone solvent over alcohol over oil. I doubt that you can do anthing to lighten the stain that is already there only try and blend in a matching shade. Could you veneer another thin layer over the stained side thus giving a clean slate to work with?
>Olive oil is not a curing or drying oil. It may eventually dry, but that will take a really long time (well after Xmas). You should be able to take mineral spirits or a suitable solvent and get the majority of the oil stain off of the piece. You will have a problem in that the walnut is slightly porous. It may take repeated wiping or rinsing.
If you didn't need a "light" finish, you could just rinse the olive oil off and then apply an oil stain. As far as your finishing - maybe you can try on a test scrap to see what covers a rinsed piece.
Brian Hahn in SW Wisconsin
>I would do repeated washings with mineral spirits - I mean flood it with mineral spirits, wipe clean, and repeat a dozen times. I'd follow that with at least two washings of lacquer thinner to remove the mineral spirits and maybe a little more oil. The lacquer thinner evaporates faster and will give you a better view of the results.
If the blotch is still there, I'd bite the bullet and use a wipe-on oil finish to even everything out.
Even blond shellac will darken the wood. I wouldn't bother with it if you are going to use a lacquer-type top coat. The lightest non-waterborne finishes I've found are Krylon Fixatif followed by Krylon Clear acrylic spray. Spray lacquer is almost as good.
