Cubic Zirconia Inlaid Ruth Niles Stopper
Steve Russell
>Hello to the group,
Here is another attempt to post a picture of a Ruth Niles bottle stopper I turned recently that has been inlaid with (24) 2.5mm Cubic Zirconia (Diamond Simulants), set in solid 18kt White Gold. Outside diameter of each stone is 3.18mm. The stopper body is made from a blue swirl acrylic acetate stopper blank, polished to 12,000 grit with Micromesh wet/dry abrasives.
The holes for the 2.5mm CZ's were drilled using a McNaughton (Kelton) ornamental jig, using a large Foredom hand piece to hold the 2.6mm drill bit. Holes were drilled approximately 1.85mm deep at 18,000 RPM. CZ (bezel hollow closed) presets were inlaid with thick set Cyanoacrylate ester adhesive. Top coat is Renaissance microwax, buffed at 3,000 RPM.
As to some of the replys regarding my original post that mentioned I mislabled my earlier posting text noting the Cubiz Zirconia's as "diamonds", well that's what you get for posting when you've only had three hours of sleep in the previous two days. :-o
I should have typed "Diamond Simulant." The first paragraph of my text did state they were CZ's, but in the title and some of the copy I should have used the phrase "diamond simulant", not just diamond. My bad... I've been putting in back-to-back 20 hour plus days of late, so I didn't catch my error.
I've been inlaying various stones, gemstones, synthetics and simulants into my woodturnings for years and the inlays are always properly identified according to established industry practices. Take care and all the best to you and yours!
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
