Wood for practice finials
GalenV
>What is a good wood to practice making first finials? Assume the turner makes MANY attempts! Thinking ripped to 3/4" or 1 " square stock x 6"+- for starting size.
Re: Wood for practice finials
Re: Maple, cherry, almost any hardwood....
Jamie D
>... with small tight grain structure. These can also be "blackened" in several ways to create very good alternatives to the usual expensive blackwood or ebony finials for finished products.
>I think poplar is a good wood to practice on. It's a little more flexible than some woods but then that allows you to learn to compensate for that problem. It also dies and paints well.
Maple is an excellent choice as well as walnut and cherry.
Thanks Jamie & John
GalenV
>I used poplar to practice beads and coves but was not sure if it was any good for fine turning. Have to stay away from walnut due to reaction. Hard maple and cherry I can get easily.
Already learned the black alcohol shoe dye is good to use. I tried permanant black marker and when it dried polished with wax and it looked good for a little urn lid I tried.
Galen
BobM
>I like to use walnut and hard maple for making finials. The grain is usually pretty straight and the wood is easy to come by.
poplar or poplar
>Make sure it's yellow poplar (tulip poplar) and not true poplar/popple/aspen. Y.poplar is much harder and cuts cleanly instead of fuzzing.
If you live near East TN stop by and I'll give you enough to cut a couple thousand pieces to practice on. I like it since it dries quickly, doesn't warp much, fine-grained, mostly clear, and big logs are abundant around here. (BTW, as well as taking paint well, it takes stain very well - it's often finished to look like cherry.)
Eastern red cedar is also cheap and good for practice. I use it a lot to make jam chucks and jigs and such as well. We have a lot of cedar around hear. I also like bradford pear, persimmon, and dogwood. Dogwood is especially nice, hard and dense and very fine grained, takes incredible detail, more like the exotics often used for finials. Persimmon cuts like ebony. Wait a minute, it IS ebony. I made an endgrain cut on a piece last night that I couldn't improve on with 600 sandpaper.
Re: poplar or poplar
GalenV
>John
I have lived in boring Iowa for 61 years. Have only driven through your state. Step-brother lived in Chattanooga after retiring from the Navy and lived on a "little" mountain top. Worked for the TVA teaching nuclear engineering. Beautiful state to live in, but I don't like snakes.
All the wood available in the USA and if you buy wood in Iowa you find it has been shippped from another country. Guess it is better for them to lose a tree than here. We do have some small saw mills but they are rapidly disapearing.
Galen
Karl Rinehart
>Pen blanks of any wood are easy to get and a good size for small finials.
boring Iowa
>Hey, I lived in Iowa for a while. Lived in Clinton Iowa (my address is Clinton TN now and I don't even like the name Clinton) and worked downstreaam at Quad Cities nuclear power plant doing NDT during construction.
What I remember about Iowa is how flat it is. My wife and I had a couple of motorcycles and we would ride around sightseeing. One day we found a hill! Zounds!!!! We went up, and down, and up, and down...
There are no cats in America and no snakes in TN. Well, a few harmless blacksnakes. Found one in the henhouse last year. Better to be afraid of the humidity and mosquitoes in the summer than snakes.
This part of the country is almost a temperate "tropical" forest - wood is abundant and free for the taking and sometimes people will haul it to you to get rid of it. When people found out I have a sawmill they started giving me so many logs I had to cry Uncle. A guy wanted to give us a half dozen walnut and cedar trees the other day but I'd have to drive ALL the way across town (whine), pull the trailer, (whine), gas up the chain saw (whine)...
If you find yourself this way sometime come and visit and we'll saw a log in your honor, maybe a walnut, sweetgum, maple, poplar, cherry, persimmon, dogwood, locust, or something else that will otherwise probably rot in the saw yard before I get to it!
Re: boring Iowa
GalenV
>John
Then you know why it's boring. Nothing but flat land around Ames and few trees. Southwestern part where I was raised had hills to make it interesting and good hunting. Paying for part of Iowa State University with two "kids" trying to finish up, so probably be here till I die broke.
Got a Yamaha V-Star 1100 sitting in the garage and too cold to ride.
Well that and a bad ticker. Ride it when I can.
Looks like the river does not know which way to flow around Clinton, TN. so guess you are not short on water.
Sawmill sounds like too much work and not enough turning time. I did not plan things well either by starting to turn wood now. Live in town now and formerly lived on acreage and cut a lot of wood but burned it all!
Life.
Galen
Brad Vietje
Brad Vietje
>Galen,
I suggest the hardest wood with the finest grain structure readily available near you. In addition to hard Maple (Sugar Maple, not Red- or Silver- or Norway Maple), I like to use Eastern Hophornbeam, a.k.a.Ironwood, Apple and Lilac. These are plentiful in New England, but maybe not where you live. I don't like Walnut for this, as it seems pretty coarse to me.
Lilac is a little-known, but fantastic turning wood, with beautiful purple streaks of color. It has an extremely fine texture, takes very fine detail, and has a waxy feel and look when cut cleanly. Lilac is sometimes avoided because it is difficult to dry in larger chunks without cracking. I split larger diameter pieces (usually 4" to 6" is considered decent sized) into quarters, which are a nice size for small projects and finials. It dries well when not in the round, and has a beautiful perfume-like smell when cut.
Safe spinning,
Brad Vietje
Newbury, VT
>Brad,
Do you have any lilac you'd be interested in trading? In several years of keeping my eyes open I haven't run across a single specimen.
Some interesting woods I have found: crepe myrtle, rhododendron root, box elder root, sassafras burl.
