Re: Nested Bowls *LINK*
Rick Allen
>I am not a big fan of the foot being glued onto a platter. First it always looks like the foot is glued on and second the foot is likely to move differently than the platter body as the wood expands and contracts with the seasons. This expansion thing is especially evident when the woods are different species.
I make platters out of 4/4 stock all the time (that works out to 7/8 when the rough part is cut off).
Procedure:
Mount the platter stock between the chuck jaws and the live center. I like to use a cup center in the live center so the deforming of the wood by the point of the live center is minimized.
This will be the bottom of the platter.
Make the platter blank round and true.
Cut an 1/8" long tenon on the tailstock side to fit the chuck jaws in compression.
Mount the platter on the chuck and bring up the tailstock as before.
Turn as much of the platter as you can without moving the tailstock. It is important to work from the rim towards the center an inch or two at a time. This is to say that the outer most inch or two of the platter should be finished both top and bottom before turning any of the center wood away.
Keep doing the a little at a time till your cuts will all occour within the jaws of the chuck. This is to say that is your chuck jaws are 3" across then the tailstock and live center should be supporting the platter until you are cutting the inner most 3" of the platter.
I use an engineers square to guide me while flattening the inside bottom of the platter.
Keep in mind the 1/8" of material that was cut out of the backside for the chuck. I use calipers often to check my progress.
I use cole jaws to turn away the tenon on the underside of the platter and to refine the foot of the platter.
I use a 5/8" (American measure) bowl gouge for all the turning except for a little dressing up of the rim/body interface where I use a variety of small tools depending on the shape.
I have a small article on my web site about making a platter which primarily follows the instructions above.
Making a platter
