Using produce rubber bands in turning.
>How many of ya'll use the large rubber bands from the broccoli or other vegetables in turning?
I typically use them to cushion the outside of tenons or as a cushion around the outside of the jaws.
Re: Using produce rubber bands in turning.
Michael Stafford
>Jerome, I had not thought of using them that way but they sure would be easier than wrapping layers of tape around a spigot to protect it. Great idea and thanks for sharing!
Have you published your lemon cake recipe yet? 8-)
Not me...
Peter Teubel
>I hate broccoli.
PS...Sorry, couldn't resist.
Jim Miles
>I use a lot of rubber bands in segmented/staved work. Use them to hold the form together to make sure it fits together before gluing, and adding various pieces to change design. They also come in handy for some glue ups that clamps won't hold - gluing lose bark back onto bark edge bowl.
What A Good Idea!
Barbara Gill, Remlik VA
>I used to keep them but eventually had to throw them away because they dry rotted. Now they will have a use. I used to use little pieces of the adhesive backed foam to pad the jaws.
>I tried using a rubber band to dampen the vibrations on the lip of goblets while hollowing the outside. It seemed to work but I've been using my fingers so long to do the same I always forget the rubber band.
I use cut up tire innertubes to glue together segmented pieces that are hard to clamp. I just clamp one end on the edge and then wrap away. Don Russell uses plastic wrap to do his which works much better I just haven't bought any yet.
Chuck Engstrom
>Just yesterday I asked my local SuperFresh produce dept. to save me a handful of broccoli bands. I'll use them to keep mating top and bottom sections of pens together when I do several at a time.
Best--
Chuck
Yep
Carole Valentine
>For the use you mentioned as well as a lot of other stuff.
Lobsta's prices are down these days. Ayah.
Jack Savona
>I've used pieces cut from bicycle inner tubes and some huge rubber bands I got once from an office store.
I wonder if you can cut them apart and reglue to the desired size like you can o-rings?
Peter: We love broccoli here. We pulled the last head from our fall crop last week and made a quiche. I still have cabbage I'd better get before it freezes solid. I think the greens are chicken feed now.
I love broccoli but my digestion doesn't. :=((
Brian Hahn in SW Wisconsin
Bob Macgregor
>What a coincidence; I asked a similar question on another forum last week. The other handy use for these rubber bands is to cover the outside edge of the chuck plates both to pad them a bit, for knuckle protection, and to make them more visible.
BOB
Texian
>John, You hollow the OUTSIDE of goblets? Please post a picture.
