pen question
pen question
pen question
gary s clarke
>What is the best way to sharpen a barrel trimmer for pen blanks?
Re: pen question
Re: pen question
Ian
>I just use a diamond card, some may have a better way.
IAN
Re: pen question
Re: pen question
Jennifer@Indy.USA
>Gary, I remove the cutter from the post and use a diamond card or diamond hone of some sort on each of the wings on the vertical side only. I wouldn't use it on the top edge ever.
Jennifer
Re: pen question
Steven Antonucci
Ditto, but I'd do the top edges once carefully
Steve Antonucci
>Once the top edge is shiny, I'd do as Jen advises. Probably only take a minute. The key is to be able to "draw file" with the diamond card to avoid rounding the top edge. It's not that hard, but it probably takes a little practice before you should try it on the pen tool.
Take a scrap of aluminum and practice cutting level with a file, then practice with a diamond hone until you are confident that you can control the rocking motion. You only need to remain level for about 1/2" so it's not that difficult.
Steve
Re: pen question
Re: Ditto, but I'd do the top edges once carefully
Cyril Griesbach
>I just did mine two days ago and I just took the cutter off the post, placed the cutting edges flat on a diamond home and slid it back and forth a few times and it worked like new again. I'm bored with pens but my wife likes to make them.
Re: pen question
Re: pen question
GalenV
>Probably not knowing any better it seemed dressing the flat did not hold an edge long. May be I let it go too long. I made this jig and the cutter is mounted on a brass rod. I have a router base for my Dremel tool. I put in my chain saw round stone and set the router guide so I can slide the cutter up to the stone and it grinds a curved edge face. I use the set screw to hold each face correct to the stone. Now dressing with a hone restores the edge between grindings.
The image is from laying on my scanner so I could not show with the router.
I coud take a picture to show both set up.
Re: pen question
Exactly
Jim Shaver - Oakville, Ont
>Thanks Claire,
This is exactly how I sharpen my mills.
Take care,
Jim
