I didn't know I couldn't do it.
>Dick Hines's experiment with bending blackwood reminded me of my early stages of woodturning. I did a lot of pieces that even today I'm not sure exactly how I turned them. Especially with the skills I had back then. I think the reason I succeeded was that I didn't know I couldn't do it. I had an idea and I persue'd it until I succeeded.
I think this is a wonderful kind of freedom. It was more about the idea and the final product than how I got there. It didn't matter how long it took or whether I did it with a scraper and 24 grit paper. it was all about problem solving and finally ending up with a finished piece.
I know sometimes it is the process itself that is the fun part. Roughing green bowls with the shaving flying over your shoulder is fun and could easily be an end product in itself.
What I'm trying to say is that when you have an idea go for it. don't let anything get in your way until you get there. If you find a stumbling block there are enough knowledgeable people here to help you jump over that block. Have fun, make things, and most of all enjoy yourself.
Re: I didn't know I couldn't do it.
Amen!
Ron in Drums PA
Ditto
Jim Shaver - Oakville, Ont
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>Great advice, John!
charlie belden
>There's something called The Bumble Bee Syndrome. Before high speed filming the Common Knowledge was that according to the rules of aerodynamics at the time - the bumble bee's wings COULD NOT provide the lift required for them to fly. Bumble bees, not having studied aerodynamic theory, flew anyway. Later, with the help of high speed filming we discovered that they get lift on both the foreward and backward wing movement.
There seems to be a lot of emphasis on developing perfect technique for a particular type of cut - using a specific tools - ground a specific way. And some are convinced that there is only one way to turn a particular type of piece - their way.
The beauty of turning is that it has a lot of bumble bees. Somebody used a metal lathe chuck on a wood lathe - and opened up a whole
new world of possibilities. Some lunatic stuck a chunk of sharpened steel in the end of a piece of pipe in order to hollow a bowl deeper than his "real gouge" could reach. Some poor soul ran out of "good wood" and, driven by his turning addiction, glued up a bunch of scraps to make a blank to turn - or had a piece he'd started and quite when he hit punky wood, or found bark inclusions. Never having gotten sharpening on a grinder down - silver soldered a piece of carbide on the end of a steel rod and used it rather than an all steel gouge.
The list goes on and on - thankfully.
Once someone showed me how to get a curved edge on a skew I reached for a skew for almost everything I turned - with the long point down - which I've been told is a No No. Maybe it was the If You Only Have A Hammer - Everything Is Treated As A Nail thing.
HOW you get there is less important than the fact that you GOT there - and ideally - had fun along the way.
I love the Bumble Bee Syndrome-thanks
Texian
>Good thoughts guys. Years ago I used to have kind of a motto that went something like "Never (within reason) let the fact that you don't know what the hell you are doing stop you from trying to do it." This did get me in trouble a time or two, but for the most part the results were positive.
Yea, John!
Allen Neighbors
Keep going, Texian!
Allen Neighbors
I can relate to that.
Brian Hahn in SW Wisconsin
>My career was spent figuring out how to do things that hadn't been done before (R&D). Sometimes we butted our heads against the laws of physics (the laws won), other times we ran smack up against the limits of the state-of-the-art technology. But mostly we expanded the boundaries of what could be done.
One of the things I really enjoy about turning is that there are always new things to try and new puzzles/challenges to solve.
Re: I can relate to that.
Reminds me of a little poster I have -
"Gravity, it's not just a good idea. It's the law."
At our lab we dreamed up many things, some of which would have been world-changing successes and brought us much fame and fortune if only procurement had been able to get us a supply of 'unobtianium'. But seriously, there is little more interesting and exciting than R&D.
Dick Hines
Dick Hines
>I get as much staisfaction out of figuering out how to hold a piece as the end result. I came up with a way to hold the lids on my fifial boxs where I do not have to use a chuck. It took a while but I think it works better. I use a bottle stopper mandrel. That way I have a hold already in the top for the finial and I can turn a little button or finial to fill he under side hole.
The blackwood bending thing was something I wanteds to do and I was determaned I was going to use blackwood. I have seen blackwood around the sides of musical insturments so I figured it could be bent one way or another.
The hard thing was not bending the blackwood it was turning the rods small enough to be to scale.
Don't let anyone tell you "you can't do that" Give it a try and if it doesn't work the frist time try at come up with a way to get it done. I personley will go out of my way to do something that some one tells me "you can't do that."
