>I am working on another box that will have , I hope, 2 blackwood rods running across the top. The rods will be running through 3 post. The middle one is a tad higher than the other 2.
Now for the $64,000 question. These rods are about the size of .5mm pencil lead. How do I bend blackwood?
>I've never tried blackwood. I bend small wood like that by wrapping them in a wet wash cloth and putting that in the microwave. It varies with the size and species and how big the washcloth is etc. A good starting point is 30 seconds. Sometimes as long as a minute. Then I put them in a form and clamp them down with rubber bands to hold the shape. You will get some spring back so if shape is critical you should run a test and see how much smaller to maker your form.
Before I used the microwave I simply put small pieces in a frying pan with water and heated it to boiling. I also have a small steam bending rig I made from a T kettle and a piece of 2" PVC with screw on caps. You need a hole for the steam to enter and one for the steam to escape and a way to hold the pipe above the kettle.
>I wouldn't think Blackwood would respond well to steam bending at all. It is so oily and dense that I doubt the steam would penetrate. You may pull it off with the tiny pieces you are talking about but I doubt it...let us know.
>I would agree with Carol if it was just steam bending but the microwaving is sort of a combination of steam and internal heat. I'll be interested in seeing if it works. I'll be in the shop on friday and Saturday. I'll cut a little chuck off a piece of ebony and see if it works. It's not blackwood but I would think the properties aren't horribly different.
>I've bent wood by heating a pipe and then bending it around the pipe. This is how they sometimes bend guitar parts. I had trouble controlling the heat and was bending a light wood so I had some scorch marks.
You probably have enough info now to do some tests. I forgot to tell you that green wood bend better than dry. Try soaking the wood in water for awhile and then use the wet rag and microwave
One more option that might work. Soak it overnight in ammonia. I used to bend yardsticks and tie them into a know doing that. It discolors some woods so do a test. This makes the wood really flexible. It takes a good 24 hours or more to dry so leave it in the jig as long as your comfortable doing so.
>I will be following this thread for your experiment's results, but note that many woods do not bend well. The USFS data sheets on wood properties often mention bending characteristics, but I find no mention in any of their Dalbegia (rosewood) species. (I presume we are discussing African blackwood (D. melanoxylon)
