turning twig pots
turning twig pots
turning twig pots
Tom Russell
>I am still trying to get some wisdom about turning downed limbs into little vases that are sometimes called twig pots. I have a bunch of nice wood that fell a year ago. How do you keep the things from cracking into useless pieces? How long does the wood have to season outside? Is there a trick somewhere about this? An article or advice anywhere? TOR
Re: turning twig pots
Re: turning twig pots *LINK*
>Tom,
I turn all my weed pots from dry or partially dry wood with no pith, but I read about someone turning them from limbs who turned them green. They will warp some but not much since unlike cross grain turning the shrinkage would be equal all the way around in the radial direction. And anyway, a weed pot doesn't need a fitted lid so even if it warps a little it won't matter.
If I cut any wood green and season, I use a big enough limb/log to cut the full piece to one side of the pith and coat both ends with anchorseal to prevent cracking while drying. I let pieces a couple of inches thick dry for as long as possible, at least a year.
If you like turning limbs, there's an excellent book you might want to check out - link below.
BTW, I made the batch in the picture once for my kindergarteners to "help make" and take home for Mother's Day. They each sanded with some 400 paper, I sprayed with lacquer, and each made a flower arrangement from little sprigs of plastic flowers. The tag said "Handcrafted by Mr John and Kristen" or who ever. This was a HUGE hit!
Turning Green Wood
Dave Halter
>Tom,
I've turned quite a few smaller things now from green wood. Definitely the biggest issue for most woods is to get rid of the pith. I tried several small vessels before I learned that lesson. They all split horribly. I recently bought the same book that John mentioned and haven't read it all yet, but it contains a lot of useful info on the subject.
Dave
