Sanding spirals?
Sanding spirals?
Sanding spirals?
>I decided to try my hand at making a "double barley twisted ribbon". And by "hand", I mean by hand. I mapped out the pattern on the turned blank, cut a kerf with my saw and rasped out the coves. I believe the column is mahogany and the top and bottoms are either maple or birch (it was free kiln dried wood, I wasn't going to ask their provenance). Needless to say, I had to sand it to get the rasp and file marks out.
You are sanding at a diagonal in the coves. I took a piece of dowel and wrapped sandpaper around it. I then sort of followed the cove and tried to go parallel to the axis of rotation. I then followed up by sanding by hand by sort of twisting the paper into a rope and going from the top of the bine, down into the cove and up on the bine. It definitely wasn't power sanding by any stretch of the imagination.
I sort of want to do this again, with some thinner pieces. I don't want to spend too much time sanding though. Anyone have any better methods to sand the spirals? TIA.
Re: Sanding spirals?
>JL for large spirals I use drum sanders on my flex shaft machine. I find the 3" long by 1" around the best for what I do. I drums in all kind of sizes. For smaller sanding drums call TheSandingGlove people. I think that is where i got my 1/8" shank drums that are about 1" long and 3/8" diameter. Very handy for smaller spirals.
For small spirals I take a strip of sand (maybe 1" by 10") and twist it so it forms a sort of spiral tube. Then I wrap this around the spiral and pull it back and forth like cleaning your teeth with dental floss. I learned this from Stewart Mortimer and it works really well.
I'll give it a shot. I rescued a large set of..
>drums from cleaning out Bob's garage. They are a bit large for my Dremel though.
John Scheideman
>How about using a small flap sander in a drill?
Re: Sanding spirals? *LINK*
GalenV
>Could you use these rotary shapers instead of your hand rasp and then maybe the time you save can be for sanding with a drum as suggested?
Rotary Shapers
>Galen, rotary shapers would have a tendency bury in the piece. They also don't go in the direction of the spiral. It is somewhat faster to use a microplane rasp. This helps to define the spiral as well as deepen it. I have a set of the rotary shapers and I use them to refine chair seat edges.
Raymond Overman in SC
>When I make spiral finials I use the dowel method you described after using a mini-drum in my Foredom to do the rough sanding. I've also put together sheets of sandpaper on a mandrel in my Foredom to do a little finer sanding. It's inevitable that I end up doing some hand sanding too.
matt overton
>Take a look at Stuart Mortimer,s book on spirals. He is the best. I have the book somewhere, but can't remember the name
Re: Other alternative :-)
GalenV
>Fined the right piece of wood or grow your own.
It just may take a LITTLE longer!
The sanding sleeves worked well - at least..
>my short ones (and one of the long ones) did. I can't seem to change the sleeve on my intermediate long sleeve - it won't slide over the rubber very well.
