PinChucks Picture #2------WebKitFormBoundary3dGynL
adrien------WebKitFormBoundary3dGynLujyAfPJZ+8
>Here's the pin chuck Steve was referring to:
Re: PinChucks Picture #2------WebKitFormBoundary3dGynL
Lan Brady
>I don't see how you use these to turn hollow Christmas Ornaments?
Lan
Chuck Engstrom
>Hi Adrien -- could you explain to me the business about "-WebKitFormBoundary3dGynLujyAfPJZ+8" that appears on your posts and seems to change a bit from post to post? I am just puzzled by what it's all about, since it sometimes seems to appear where I would expect your name to be.
Thanks--
Chuck
It probably means he's using Opera ... *LINK*
Brian Hahn in SW Wisconsin
>It is a know anomaly with the Opera browser. See the "Messageboard FAQ", item #13. (Link below)
Alphabet soup
adrien
>Chuck, I've no idea where that came from. Periodically the site adds something to my name and when I catch it on a response, I take it off. I cannot find it in my data file. I think I am haunted by the ghosts of trees I've failed to do honor to in my frantic attempts at woodturning.
adrien
>If you look closely, you'll see a little "pin" or bar that will, under centrifugal pressure slide along the dado to the side of the hole that the bar is inserted into. That pin sort of jams the bar into the hole and holds it while spinning. It falls away when the piece is not turning and the chuck is then easily removed.
thanx Brian. I'll try to fix it
adrien
