Signing your work question?
>My son has turned a nice walnut box. The question is what to sign it with. And when. He is about to Bealle Buff it. He has signed it with a Sharpie Micro point. Now he thinks that will buff off. How would you do it. Before buffing, or after? What would you use?
Re: Signing your work question?
Fog Tanner
>For items like that I use a woodburner before applying any finish. For the pieces that I use liming wax, I use an engraver and then fill in the name with liming wax. I have used the engraver and one of the "gold sticks" that Cindy Drozda uses on some items.
On some of my current dyed pices, I use just the engraver with no wax and the name is still readable - just a little less intrusive.
Fog
>It will buff off. If you can put another coat of finish over it. Test it first because some finishes will make the ink run. That's part of why I went to the engraver.
nick
>Test the ink before you apply the finish. If the finish dissolves the ink, try a different ink. Usually, two coats of shellac will seal in the signature, in my experience.
this might be interesting  *LINK*
signing thread
I Burn Before Finishing
Barbara Gill, Remlik VA
keith zimmerman, Normal IL
>I use an engraver to sign my work, then finish.
keithz
Wayne Leach - NW Ontario
>Barry,
I was a design drafstman for many years but was never satisfied with hand signing so I went to that shown in pic enclosed.
I cut a recess in the base and make and install the photo in the recess with super glue, then mix up and pour in a small amount of "build 50" or other decoupage to seal it in.
I use a label program on the computer and pick a circular template the size I need and then put the image and text in.
I am going to undercut the recess from now on and make the label/photo a smidge oversize so the edge will not show.
Just one more way to do it and I use a different photo for each turning.
This image is my best buddie Sabre-he is a 10 year old German Shepherd.
Everyone seems to like getting a bonus image in the base?
Best regards,
Wayne
jim miles
Jim Miles
>Barry
I use a sharpie to sign. Lacquer or varnish will desolve the ink. I put 2 coats of Minwax water base poly on it, sand between coats, it will raise the grain, can usually do 2nd coat in 30 -60 minutes. After dry - lacquer or varnish or petro-based finish won't desolve it. I keep a plastic salad dressing bottle with fa little poly & a cut off brush that stays in the bottle for this use.
Bill Blasic
Bill Blasic
>As in the thread that John pointed to I have been using the Pigma Micron .005. I have found it does not run or smudge with some finishes as the Sharpie did. My penmanship is not the best and the Pigma makes my signing look better as compared to burning and vibrating.
Charles Watson
>In the future I would recommend using a pen which has archival ink, which Sharpie does not have. A Micron pen among others has this type ink. Preferably the piece should be signed before any finish is applied. On dark woods such as Walnut I typically use a Dremel engraver.
Re: Signing your work question? *LINK*
Ron McKinley
>Here's a handy engraver for signing your work. I've been using one for several months now and it's easier to hold than a Dremel style.....Ron
Micro Engraver
Tom Stevenson
>I use good old India Ink and a steel pen. Nothing seems to dissolve the ink except water. (Which is the way I correct my spelling.) Put down a coat of your favorite finish on the wood first. Sign, describe the material and date it with the ink. Then a coat of finish over that.
