Meat cutting bandsaw?
jim miles
Jim Miles
>I've been offered a meat cutting bandsaw.
Does anyone know anything about them?
Are they usable or convertable to cut wood?
Re: Meat cutting bandsaw?
Dave Peebles Lyons, Ohio!
>Hi Jim,
If the height will work for you it should be fine. I have only seen one for sale. It was at an auction and was built like a tank. It also had a sliding table on it, and had a SS top. I have often thought that it would have worked great for halving bowl blanks. But, alas, I was a poor uninformed flat worker in those days. :) Also the height was rather low as I remember... maybe 6"
I would sure take a look at it.
Dave
>I bought an inexpensive one from Northern Tool for a friend who processes a lot of meat. But if the one you are looking at is like that one, I would not want to use it for wood except for very thin material - the castings were puny, the table small and would not tilt, didn't have much height above the table, the motor was too small, it will only take a small blade, and the general tolerances were sloppy. He said it was great for meat but I doubt he ever needed precision cuts. It was all stainless steel - he keeps it outside on the back porch.
If it is an industrial model it might be a different story. As Dave said, take a look. See what the motor size is.
Mike Stafford
From some of the stories I've heard....
Mike Stafford
>all bandsaws that cut wood will also cut meat. Usually when that happens it involves a trip to the emergency room. I do not know if the inverse is true....
Steven Antonucci
Universal truths
Steve Antonucci
>You don't want to turn stone on your own lathe (find a friend that you don't need anymore...:-)
You don't want to cut meat on your own wood bandsaw (impossible to clean and your shop will eventually smell like roadkill...)
I'm sure there are others...
Don Evans
>To answer you directly, yes, it will cut wood. The only thing that determines what you can or cannot cut on a bandsaw is the blade you are using.
I, like the others, see many variables however that would or could be very aggrevating depending on the saw itself. A cheap one that an individual purchased is probably a "forget" it. One that was purchased and used by professional meat cutter MAY be worth a look at. It could make a second "special" machine to do one specific job in the shop.
Not long ago, I read an article about a guy who does woodworking and used only stainless steel blades made for meat cutters. Cannot at moment remember what magazine.
Don
robo hippy
>One of the guys in our club has one, and has used it for years with no problems. He is a master at simple solutions for broken things, and did some work on it, but not sure what. It should be worth a look at least.
robo hippy
Brad Chenoweth
>Hi Don,
I remember that article too. A Google search turned up David Charlesworth, Pop. Woodworking, April 2008.
Brad Chenoweth
Bob Trucchi
>In another life I used to be a meat cutter. The main difference I recall is that the throat is on the opposite side, the table slides and the only adjustment you could make was blade tension. I�d lean towards staying away from it .
Keith Tompkins
Re: From some of the stories I've heard....
keith tompkins
>Mike, I once loaned my delta 14"bandsaw to a friend. He never returned it, so, I drove to his house, and there was my saw in pieces. The tires were gone, he had tried to operate the machine without them. He had neglected to tell me he intended to cut up a deer with it....the rubber tires expanded, swelled up, and fell off as a result. Without the tires, it wouldn't keep a blade on but that didn't stop him from trying. Haven't talked to the guy in over 30 years. I no longer loan tools.
I have one of those.
Pete Kekel - Kentucky
>I have an older model Biro 33 meat cutting bandsaw. The table has been replaced with a cast iron table saw table (miter slots run the wrong way) that measures 27" x 36". There is 14" of clearance under the head and I run a 3/4" blade on it. There are no 'guides' to speak of, but with the big heavy table and size, this is the perfect tool to take the corners off of big bowl blanks. Lots of small cuts to make it round, but it does a nice job. Running a 1-1/2 hp Marathon motor.
