Lucas - glue for mirrors
>John Lucas - you mentioned that you use a few drops of epoxy when you put together one of your hand mirrors. Is this for the handle?
From your message in April you said you fastened the glass with clear silicone caulking. Do you use a ring of glue or a few dabs?
I finally made my first hand mirror tonight, turned from wormy American chestnut. Nothing like your refined work but it still looks interesting with all the holes. I held a 3/4" blank with a couple of threads on a screw chuck to turn the front and mirror recess, then expanded chuck jaws into that to turn the back. (I didn't have the patience to use the glue block method you described but this worked OK at the expense of wasting more wood).
I need to get better round mirrors - I bought some a while back from a craft store and they stink - the edges are not pretty. I spent 15 minutes with diamond hones cutting a bevel on one by hand before it looked OK. I think I'll make a jig to chuck the rest in the lathe and grind the bevel.
Do you still have glass for sale as you mentioned in April? If so, I'd like to buy some. Are they beveled?
They are pretty expensive at Woodcraft - $4.50 for one 4" mirror. I found straight 4" mirrors online for as little as .65 each but no way to tell the quality. I can't find any 4" beveled mirrors online.
Re: Lucas - glue for mirrors
>John I use clear silicone caulking for the glass. I've tried 4 large drops and it seems to work but Usually just make a ring about 2 1/2" or so in diameter. I kind of like the popping sound when you push the glass down and a bubble breaks through the ring. Makes me feel like the mirror is down flat.
I do sell the 4" bevel edge mirrors for considerably less than $4. These are also slightly thicker than the ones at Hobby lobby. E-mail me and I can give you the prices. Right now I have them in 2" 3" and 4" but I probably won't carry the smaller one after I use them all up. I can also get larger ones up to about 10" if I remember correctly.
GalenV
>John
I thought I read an article about one of your demostrations and it indcated you used CA glue to hold mirrors. I think it was an older article so sounds like you have changed. I know they make an adhesive specificaly to hold mirrors that will not damage the surface.
Did you learn by experience what worked best for you?
When I made some wine stoppers I glued some madallions or coins on the tops of a few and really had no idea what glue to use. Did CA on some, silcone on one and by mistake one of the expanding glues and used to much.
The silicone was probably the safest for smooth metal to wood. Do you have a suggestion for best metal to wood?
Galen
>Galen Nope, I've never used CA glue for the mirror. I do use it to glue the waste blocks on and long ago I used it to glue the handles on but I had several failures doing that so I switched to epoxy for the handles.
I did try some other things to glue the glass in, one that caused me major heartaches was liquid nails. It seemed like it worked well but in 6 months they all started falling off. Fortunately I had made a large batch of mirrors and still had most of the ones glued with this stuff. The silicone has never failed. It looks, smells and probably tastes just like the Mirror adhesive they sell at my glass place except the silicone caulk costs about 1/3 as much.
gary s clarke
>John, have you tried double stick tape? The advantage is if the mirror breaks the tape is easily removed with acetone.
>I did play around with double stick tape for awhile. The foam backed tape left the mirror a little wobbly and the cloth backed tape is thin enough that I had to make the hollowed out part a lot flatter which took more time. The silicone is only $5 for a large caulking tube and I get a lot of glass glued in for that. It's also handy to have around when you find a leak in the shop.
Don Evans
>Clear silicone is the preferred adhesive to use for mirrors.
Couple of things, one is the adhesive used can and will damage the backing on the mirror but silicone will not.
Second the adhesive has to be flexible for different expansion, wood verse glass in this case.
Make sure you use ONLY clear as other sealants, like for drafty windows will not have the holding power that the clear has.
Don
