turning rock
Gerrit vanKommer
>I've seen and heard of people turning solid rock. Are there any books, videos or reccomendations for learning this practice. Also does anybody know of specific rocks that turn better.
turning rock
Gerrit vanKommer
Re: turning rock
>Do a search for turning Alabaster. I'll bet you'll find a bunch.
Re: turning rock
Dick Coers
>Soapstone turns like butter, REALLY REALLY DUSTY butter. The bad thing about soapstone is the fissures that can run through the stone. Thin CA glue is a must to have around. You can't turn it as thin as alabaster. The best advice I have heard about turning stone, is to turn it on somebody else's lathe.
Re: turning rock
Gerrit vanKommer
>I tend to turn almost everything on other peoples lathes (I hate cleaning). That is great advice.
Re: turning rock
>Article in Woodturning Design magazine, Winter 09, issues #20: Learn to Turn Stone.
Re: turning rock
Gary Ljostad
>Here is a site to check out. www.exoticvessels.com/dvd/index.html
Re: turning rock
Jim Shaver - Oakville, Ont
>Turning rock is all relative to how hard it is, it�s provenance and the technology you have to turn with.
If it's a silicate based rock it will be very hard and very brittle, if it's a medium metamorphic or sedimentary rock it will be softer but still too hard to turn conventionally. A low metamorphic or soft sedimentary or even an evaporate type of rock is still very difficult to turn with conventional tools but some can be..generally with even HSS tools. Volcanics of any kind are like glass in crystalanity and very brittle.
As a geologist I commonly used diamond tipped tools on water saws etc. to cut rocks for samples and diamond plates and pastes for polishing... it's not a cheap process.
Take care,
Jim
max krimmel does it
Steve Antonucci
Re: turning rock *LINK*
Larry Bisbee
>Here is an article "Alabaster on the Lathe" by Max Krimmel that appeared in the January/February 1989 Fine Woodworking magazine. Check out Max Krimmel's web site http://www.maxkrimmel.com. There is a lot of good info.
Fine Woodworking, January/February 1989 article
Re: turning rock
Richard Allen
>Alabaster or soapstone are your choices.
These stones turn with scrapers. The stone sands to a very fine surface. Both soapstone and alabaster can have silica inclusions. You can't turn out silica. Silica will put a nick in your tools so when you encounter silica (tick tick tick) stop and dig out the silica.
Re: turning rock - Granite and Marble
Steve Russell
>Hello,
You've gotten a lot of good responses thus far about Alabaster and Soapstone. The suggestion about doing it on someone else's lathe is also good, unless you have a really good dust collector. :-o Turning both of these stones creates copious amounts of dust.
Early next year, I will begin a series of experiments on turning other types of solid rock, like Granite and Marble. Turning or shaping these rocks takes special equipment and tools. The protocols will have to be developed from scratch for the most part, since they will be incorporated into woodturnings, but that's half the fun of experimenting!
I've already started collecting some of the tools I need, with more on the way. It should be a stack of fun... :-) Take care and all the best to you and yours!
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
