Re: Stick Fast epoxy?
Chuck Engstrom
>The initial expense is daunting but you can mitigate this by using syringe type dispensers to measure as little as you need without much waste -- that's one reason I'm still using stuff given to me twenty years ago. The West System pumps are fine if you're using substantial quantities in a big project but generally give you much more than needed for small jobs like filling in cracks in a turning.
I got a couple of small syringes from my vet and set them up on my little jars of System Three Clear Coat, one parked in a tight-fit hole drilled in the top of each bottle. I've mixed as little as 0.6 cc total resin plus hardener with reliable and repeatable success. In my big jars of standard S3 resin/hardener I have big syringes I bought from them, and again, I've had reliable and repeatable success doing as little as 2 cc resin, 1 cc hardener. BIG savings. Bring the plungers well back up the tube of the syringe when you set them aside for a while.
Best--
Chuck
