Can I keep a lathe outside?
ILYA ZAVORIN
>I am contemplating buying a new lathe. This would be my second one. The one I have now is a used Central Machinery lathe that I bought for $100 almost two years ago. Since I don't have a shop or a garage, I have kept the lathe outside year round covered with a large grill cover. It was functioning fine up until last summer when the speed lever stopped working. Which is probably what could be expected in the damp climate of suburban Maryland.
So the main question is whether it's worth buying a new lathe if I am planning to keep it outside? Are there certain lathe makes/models that you would think would fair better under the elements? Is there a better way to cover it than a grill cover? Is there any type of preventative maintenance that should be done to extend its life?
Almost forgot to mention: I've turned only bowls and platters so far, so I need a regular size lathe rather than a mini lathe.
Thanks much.
Re: Can I keep a lathe outside?
Dick Coers
>If you can't convert any space indoors to make the lathe fit, I vote wait. Cast iron and steel will never work outside in your location. Better find some friends with a nice lathe, or look into taking several classes at Woodcraft.
some possible options
>If I had to keep a lathe outside, I'd look for the simplest mechanically - no reeves drive, no electronics.
I've known two people who have kept planers outside all of the time for years. I don't know what one does, but the other guy put a moisture barrier down first on the ground, sprays his down often with WD-40, and covers with some good tarps.
Can you build a little leanto roof and maybe hang tarps on the sides?
Do you have any room on the lot? How about one of those portable carports? Some have enclosed sides? How about a portable building? I bought a 12x16 a few years ago for about $2300 - very well built and delivered and set up for $50. It doesn't need a flat spot - I put mine on a slope.
If you have more room, you can more space for less money by buying one of those 8' wide steel shipping containers. I saw an article once where a guy set up an entire woodworking shop in one. Very secure as well.
Cheaper per square ft is a semi trailer with the wheels removed. I bought one 8'x45'x9'high for storage near the barn - it was about $1600. I did have to create a flat spot. It needs no foundation - just a few 4x4 or 6x6 PT timbers to set on. An aluminum trailer might outlast a steel storage container since the roof won't rust.
Re: some possible options
ILYA Zavorin
>Thanks John. I've never heard of moisture barriers before, so this is something I will definitely look into. Unfortunately, my lot is too small for a large shipping container or anything similar. Also, I think I actually want to stay away from any structure with more or less permanent sides because otherwise I will have to worry about dust removal which is something I am trying to avoid. But a leanto roof is an option.
Chuck Engstrom
>Hi Ilya -- the big problem here in Maryland is the few days a year when we get a sudden burst of warm humid weather following days that were much colder. The metal parts -- particularly lathe beds, saw tables, and similar large mass pieces -- remain cold and draw condensation from the warm moist air. It's almost impossible to prevent, no matter what you slather on the exposed cast iron, and the internal parts are even harder to protect.
On the other hand---My bandsaw has been out on my porch for a couple of years now. The raw cast iron top of the table gets a couple of coats of Minwax Wipe-on Poly every once in a while, and I keep a large plastic leaf bag over as much of it as I can cover. So far, I haven't had much problem with rust on the table.
Remember the wisdom of Neil Young: Rust Never Sleeps
Good luck with it--
Chuck
ILYA Zavorin
>Thanks Chuck. I am wondering if I can build some sort of hard cover for the lathe, e.g. out of wood or sheet metal. Of course, it's unclear whether it can be made well enough to keep most moisture away. And also taking it off and putting it back on may be a major pain.
Re: Can I keep a lathe outside? *LINK*
Stuart Johnson
>Another option might be a Rubber Made type storage shed. You could probably build something so the lathe was mobile and could be moved out when you wanted to use it.
storage sheds
>A moisture barrier can simply be heavy plastic sheeting on the ground covered with something for the lathe to stand on such as piece of painted pressure-treated exterior plywood, or better, a small platform built from PT 2x4 and PT decking boards. If you keep the lathe covered with a tarp or something that reaches to the ground, the moisture barrier will help keep ground moisture out of the space under your cover.
Philip Morris
>Ditto previous responses regarding covering and preventing moisture from getting on it. As far as moisture condensation, you might consider attaching heat tracing (typically used to keep pipes from freezing) to the underside of the lathe bed to keep it above the dew point of the ambient air.
In any case you should make sure that your power supply is equipped with a Ground Fault Circuit Interupter (GFCI).
gary s clarke
>If you do not use your lathe a lot you could take it apart after using and store it in an out of the way place in your house. You would need a lathe that could be moved easily. Our club has a jet that one of the members made some wheels for moving and the wheels are easily removed for when the lathe is in use. We store it in a trailer between club meetings.
Brian McKearney
Brian McKearney
>I agree with Stuart. I would look into some sort of Rubbermaid or similar brand storage "shed". These aren't in any way permanent, but they are pretty durable and offer some protection from the elements. I doubt that you would want to turn inside of one, but perhaps you could buy/build some wheels that would allow you to move the lathe in and out whenever you want.
Brian
jim miles
Jim Miles
>I agree with the Rubbermaid approach. Thet have a short plastic box that is designed to store a lawn mower in that might be just the right size. Check your local Lowe's. If not on display, they have catalogs etc and can order for you. Also agree with moisture barrier floor-really need that. I used to live in Rockville- where are you?
Dick Hines
Dick Hines
>Even in a unheaterd shed you may still have troubles. My motorcycle is in a garden shead. My wife bought me a cover for it last year. It works great to keetp the dust off but when we have warm days after a string of cold days I get dampness all over the bike. I have started just covering part of the bike.
Bob Barkto
>Think of it as a lumber drying shed.
As a few of the guys suggested, a non-breathing cover is nothing more than a moisture trap and will likely do more harm long term than occasional rain.
You need airflow as well as shelter from the elements. The sooner the inside of the structure and its contents can acclimate the better off you'll be.
A roof with overhang with some breathable material for the sides will keep the rain out and help preserve airflow to prevent condensation problems.
A moisture barrier on the ground will keep ground moisture from precipitating into the structure.
If you can place it next to an existing structure it would probably be easy to mount an overhang for a roof, three slatted walls covered with a breathable fabric (weed barrier maybe?), hinged or otherwise removeable and the sides can come down in short order to give you access.
Just a few thoughts, hope they're helpful in some way.
ILYA ZAVORIN
>Thanks, this is helpful. I guess the idea of an airtight cover is no good. The lathe does stand next to the house but a roof with removable walls is not very practical because this is a high-traffic area. I am wondering if a small shed that another person has suggested is a better alternative. If it has small windows I can even put a low-powered fan inside to decrease condensation. Also, I am wondering if this would also be a better solution for long-term winter storage when I don't turn outside.
Ed Karch
>I have my compressor outside with only a tarp. It does get wet with this area's high humidity followed by cool. I would try a small shed with either roll out lathe capacity or a stationary lathe with a roll off shed. Many amature astronomers use the latter for telescope protection. In either case a light bulb under the lathe could supply enough heat to suppress the dew problem.
Ed Karch
>Talk to me next MCW meeting, I have several ideas and I am building an open shed for my blacksmith shop which might work for your problem.
ILYA ZAVORIN
>Thanks, Ed. Will do.
