First segmented bowl
Jim(IN)
>Hi All
Been dabbling in a little segmented bowls/vessels for a couple of months. Have Malcolm's book & just recieved Kandler book & video. I can only dream of producing some awesome bowls that I have seen on this and other sites.
Have a bowl on the lathe now that i think will be firewood due to out of round glueup. Good experience I suppose. What has been the best way for some of you to glue up a perfectly round bowl? I feel that I get it all lined up properly and then when I get it on the lathe it isn't. Made a press like Ray Allen book.
Just last week I finished turning a nice beginners 3 layer bowl(thanks Dennis Daudelin) and sanded to 320 and put on Minwax wipeon poly on and it still hasn't dried. It seems that the maple is dry but the padauk is still tacky. It has been over 48 hours. Any suggestions?
Hopefully a photo of my best so far will appear with this post. This has been my best work to date.
Any and all suggestions for a beginner are welcome. I would rather not "reinvent the wheel"
Thanks In Advance
Jim Swift
Re: First segmented bowl
Jim Shaver - Oakville, Ont
>Nice Work Jim,
You have more patience than I do wfor thos type of work
Take it easy
Jim
gary s clarke
>Hi Jim, one way to get good alignment of the rings is to glue them up on the lathe using a cone on the tail stock. You can make your own or buy one from Curt Theobold. Curt also has a good video on segmented bowls. Another way for alignment is to have a large plexiglas plate with circles of various diamenters and place this over the ring to be glued and aline the ring with the correct diameter.
Keith Tompkins
keith tompkins
>Hi Jim, Great first attempt! A couple of suggestions: First, the "beauty Ring" is very centered on the vessel, raising it a bit will help balance the piece. ( Study Curt Theobold's work) Also, try to keep a smooth, consistant flow in your form... the shape seems to flatten out near the ring. A very easy way to dress up a segmented turning is to add black and white veneer between rings. It's easy to do, and looks good too. Nice work.
Re: ring alignment, link
gary s clarke
>One way to align rings. link http://www.woodturningonline.com/Turning/Turning_content/centering_segemented_bowl_rings.pdf
Texian
>Jim, I build most seg. pieces on the lathe and use a cone center (as mentioned), or a Longworth chuck, or sometimes a jam chuck to center successive rings. The jam chuck is a piece of "scrap" in a scroll chuck, turned to fit the next ring. Scroll chuck is then put on tailstock using an adapter (1-1/4-8 to MT2). Could also use the big flat jaws (Cole, jumbo??) on a scroll chuck.
Jim(IN)
>Keith
Thank you for your response. I have been trying to study forms etc. I appreciate you advise.
I have been recently looking for a supplier for white & black veneer. Any suggestions or comments on where you get yours.
Are all your bottoms one piece or do you use multi pieve bottoms?
Thanks
Jim Swift
Thanks for link
Jim(IN)
Keith Tompkins
keith tompkins
>Jim, I have found that bases made from layers of veneer glued up crossgrain are the most stable. Bases made up from Pie-shaped wedges have been a major disappointment....they open up with seasonal changes. A floating base, as Malcolm suggests, works well. My supplier of veneer no longer sells small quantities, so we are in the same boat.
jim miles
Jim Miles
>Jim:
Nice start for a beginner!!
Another trick to getting enough width to be able to turn it round is to make your segments wider - outside to inside distance, or the width of the stick you are cutting segments from. This allows you a little more margin of error if you don't get proper alignment, Several other good suggestions in thread. But most of all- keep cutting & gluing segments and making stuff- thats how you learn. Don't get to carried away to start with fancy patterns & designs, you can graduate to that later. Good luck!
Tom Vensel
>I use the methods I learned at www.turnedwood.com . To glue up rings nice and true , I made the press that he shows how to make listed under "tools" in the website . Tom ,,,
Thanks
Jim(IN)
>I appreciate everyone's comments and suggestions.
Jim
