Liming Wax
Liming Wax
Liming Wax
DaveG
>I just read the article by Peter Westermann in the Woodturning magazine where he is showing several different bowl finishes. But he talks about using a Liming Wax which turns the grain of the bowl white. I have never tried this before and was wondering what steps are taken to apply it? Would you apply the normal finish to the bowl and then apply the wax? I would think if it was on the outside of a bowl and it is handled the wax would change colors.
Thanks
Re: Liming Wax
Re: Liming Wax
Bruce Forrest
>This piece ash hollow form was dyed, then the dye sealed with Antique Oil, then limed. It was then finished with spray lacquer. About 10 inches tall.
Re: Liming Wax
Re: Liming Wax
DaveG
>Thanks Bruce, I had no idea that you could spray a finish over the wax.
Re: Liming Wax
Re: Liming Wax
Ed Moore in SW Virginia
>Dave,
After you have sanded thoroughly you should dye the wood. Then, apply some sanding sealer or lacquer to seal it before you apply the liming wax. If you don't, the dye will leach into the white wax and you will probably not like the results. Then, as the liming wax directions suggest, after wiping off the excess liming wax, apply a coat of a good clear wax. This coat will make the piece look much better than it does before it is applied. Then apply lacquer as a finish coat if you like.
A limed box made of ash is shown below.
Ed
Re: Liming Wax
Re: Liming Wax
>Dave I haven't used Liming wax per se but have used other waxes to get similar results. I've use white or color shoe polish. I apply a coat of sealer (usually lacquer) and then put the wax on and wipe it off. If it doesn't come off easily enough I use a very small amount of mineral spirits to clean it off. In some cases this is my finish or I might add a layer of wax over it. If I want a glossier look I spray a coat of shellac over the wax and then spray lacquer over that.
I have also used Rub-n-buff the same way.
Re: Liming Wax
Re: Liming Wax
Norm Smith
>Dave, Liming is used on open grain wood so after sanding be sure to either blow the dust out of the pours or use a wire brush to clear it out . After dying the piece use liming wax to fill the pours and so on.
Norm
Re: Liming Wax
Re: Liming Wax
Fog Tanner
>I do a number of dyed and limed pieces. I try to do them on the lathe, but have done a number off the lathe. After dyeing, I seal with shellac sanding sealer, but not enough to fill the grain. You appply a coat of liming wax with and across the grain, filling all the grain. I want a "film" of wax and not a heavy build up.
After letting it set for 5 or 10 minutes (depending on the temp), I remove the excess wax. This is done by making a pad of Viva paper towel and using wetting a small area with Liberon Finishing Oil, and with the lathe running - start in the center and wipe towards the rim. I usually make it part way across bfore changing the pad and repeating the process with more oil starting where I left off. I only make the one pass. After the oil has cured I add another coat or two and then some clear wax over that. I have also used some home made Danish oil and received some good results.
I use the same process with patinating wax (black)for different effects. Usually on Rosewood or yellow dyed pieces. For liming and patinating, I found that Ash works the best due to the grain.
If it makes it, here is a picture of an Ash jewlrey box that was dyed and limed with the process above.
Fog
Re: Liming Wax
Re: Liming Wax
keith zimmerman, Normal IL
>I like to use Liming Wax after dying any open grain wood. So far I have done Ash, Catalpa, and Walnut, with great results. I seal the piece with spray lacquer prior to applying the Liming Wax. I have found that if I don't, the wax doesn't come off very well at all.
Good luck with this stuff.
keithz
Re: Liming Wax
Re: Liming Wax
Clay Foster
>There's nothing magical about liming wax. Any pigmented filler will work. Vinyl spackle colored with acrylic paint will give you any color of filled pores you want.
Re: Liming Wax
Re: Liming Wax
>Clay was the first person I saw do this. I won't tell how long ago that was because it will give away our age. I have used drywall mud and lately I've been using powdered wood filler that I color with analine dye. Since it mixes with water you can make in any consitency you want and it's easy to color. It's tan however so you can't mix white unless you mix white paint in it.
It is harder to get off than wax if it starts to harden. You have to sand it of and then you risk sanding through the other color layers. Work fast and keep a spray bottle of water handy.
Re: Liming Wax
Re: Liming Wax------WebKitFormBoundaryh5w1xpE+BVXL
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Not trying to hijack this thread -- but this vessel is just terrific!
------WebKitFormBoundaryh5w1xpE+BVXLyk34
